Ok I bought a 92 Firebird 3.1 around a year ago and it wasn’t running when I got it. The P.O. Had replaced the entire distributor, plugs, IAC, and fuel filter trying to fix a misfire and one day it just stopped being able to crank and he sold it to me. I fixed the no crank and got it running again and am in the middle of trying to figure out the misfire.
The problem I’m having has some really weird symptoms I’m going to list everything I have noticed but it might not all be important
1. A really bad misfire at idle that gradually gets worse as the car warms up
2. If I fluctuate the throttle around just above idle the misfire gets significantly worse sometimes causing the car to die
3. While it’s misfiring if I open the throttle just the slightest bit the car immediately revs up to 3000rpm
4. If I unplug the tps the car immediately revs up to 3000rpm
5. It has a much higher fuel consumption while misfiring
6. If I let the car get up to operating temp the tach starts jumping around (like up to 5-6k rpm) even though the rpm is staying relatively consistent
7. Check engine light with code 33
I fixed a few vacuum leaks throughout the car. That didn’t change anything. Then, after some research I replaced the ICM and I finally heard the car run “normal” I drove it around a bit and nothing seemed bad I parked it and disconnected the battery to clear the check engine light. Later that day I started it back up and it was back to its old habits. I went back into the distributor to look and see if anything was different and it wasn’t so I put it back together and started it back up. It ran great like a normal car for about 2 months during that period I changed the plugs again and wires with them. randomly a couple days ago it started again and ever since it’s been off and on running good and bad I haven’t been able to figure out what causes it to switch between running good and running bad
Any advice would be greatly appreciated and thank you to anyone who read that whole thing
