Hello: I am trying to repair the speedometer on my Son's 89 Trans Am. When we bought the car a while back, the VSS was disconnected. Plugging it in, the speedometer will jump over 120 MPH when the vehicle is only doing about 5 MPH and shut the engine off. I replaced the VSS and same problem. The car came with another instrument cluster so I tried swapping that out and again no luck. I connected a scanner and it reads the same MPH as the speedo so I figured the Buffer box was faulty. Changed that out and again nope. I thought that maybe the wiring from the VSS to the buffer was damaged so I made up a temporary harness and again nope. I found the test procedure in the GM manual for the VSS and buffer and all checked out except the ac volts from the VSS seemed high. I got just over 2 Volts turning the rear wheels by hand. If I recall 4 or 5 volts is max and would expect 2 volts around 50-60MPH. I've inspected the VSS reluctor ring for filings in case that was causing too many pulses but it was clean. I have also unplugged the red cruise control wire from the buffer in case it was feeding back and causing a false signal somehow. I'm running out of ideas. Any input would be appreciated. Thanks Don
