1 - 16 of 16 Posts
Hey Im just wondering what kinda gear ratio I can put in my stock 10bolt to get more torque. Im sandblasting and powder coating it so I might aswell throw some good guts in there while its off the car. Thanks in advance
If you have the 2.73, 3.23 would be a nice improvement. 3.42 is an option too if I recall correctly. Personally, I wouldn't go higher even if I could. 3.23 is a good balance between performance and economy.
Depends on your current ratio. There are different carriers and you may need to change depending on what you have and what you want to go with.
Also depends on how you drive your car. I like the ability to drive on the highway so when I swapped mine I went from 2.41 to 3.08. I personally wouldnt ever go any numerically higher than 3.08 for any kind of highway driving unless it was only literally every once in a while.
I wont be doing highway driving, Im thinking more a light to light cruiser, I was thinking of 3.42 or maybe higher, Im looking for torque
I always thought a gear is a compromise situation. Depending on what cam you have, how much torque the engine itself makes, what is your expectation for acceleration, and of course what RPM do you want to cruise at...and at what highway speed. If you say I want to keep my engine RPM below 2300 at 70 mph, and calculate back to see what you get, and say it comes out to a 3.23, and that is a good improvement from what you have now, then OK. Or go at it from the other direction, and say I want to increase my rear wheel torque by 35%, and that maths out to a 3.73, and you don't really get on the highway that often, then that may work best. In the end, for the street, in a car you may find yourself on the highway going 70 MPH, a 3.42, or maybe a 3.55 if you want to stretch it is where I would draw the line. In a 3600 lb. Firebird with a 301 you may want to go 3.73 if you really want a big jump, but be aware that you will wish you had an extra gear if you get on the highway. With a 400 or 455 for sure, a great street gear is 3.08, but the bigger engines make more torque at the flywheel so they don't need the gear a 301 may need....it's a trade off for sure. Gears are like cams, don't go too crazy and you will like it better.
Thank you, thats exactly what Im looking for
Very good write up Joe :lol:
I've had two cars with 3.73 gears, one was an ElCamino and the other was a 70 Vette. The vette was a 4-speed car...ran about 2800 at 72 mph and got about 16 mpg....I always drove a little spirited.
I love a 3.73.
Ive had two cars with 3.73 gears, one was an ElCamino and the other was a 70 Vette. The vette was a 4-speed car...ran about 2800 at 72 mph and got about 16 mpg....I always drove a little spirited.
I love a 3.73.
Did you have a 35in tall tire out back or something? My T/A is a 4 speed with 27 diameter tires I swapped to 3.08 and thats 2600-2700 rpm at 70.
Love the topic. With changes like this, doesn't the speedo cable gear have to be changed? This is a bit of a mystery to me, my '75 had the borg warner swapped for a Muncie years ago before I owned it, and at 60mph on my speedometer I am really going 71-72 mph. My neighbor is a state trooper, so I know for sure,... his gov car is FAST! How or where do we calc what we need for these speedo gear ratio changes when we change components of the drivetrain?
Brad
Yea, speedometer gears need to be adjusted. There is a drive gear, which is on the transmission output shaft and not easily changed, and there is a driven gear which is what the speedo cable attaches to and is easily changeable.
If you need to increase the speed your speedo reads you need a driven gear with less teeth. 16 or 17 teeth are the fewest if I remember right but it also depends on what drive gear you have. If you need help ironing out what to do to correct it start a thread for that and Ill try to help you the best I can.
Thanks guys, will start a new thread. I have tried those calculators previously, that TCI one shows not available.
Odd.... TCI works for me. It's a link I've used many times over the years.
Try entering manually (delete space after "www.")
www. tciauto.com/speedometer-gear-calculator
If you mean it shows "gear not available" when you enter the data and hit "calculate" it means there is no appropriate gear available.
Old thread. But I'm just seeing it. And, just because a thread is old, that don't necessarily mean nobody is interested in the subject.
My only Pontiac street car was a '69 GTO. I ordered it with 3.90 gears. Put 60k + street miles on it. Loved it. I wouldn't consider anything numerically lower than 3.42, unless I planned lots of 70mph cruising.
But, obviously, if someone wants LOW rpm highway cruising, the low numbered ratios will suit them better, out on the interstate.
There is another option to recalibrate the Speedometer than changing the drive gear, you can mount a reducer gearbox to the speedo drive in line with the cable. They come in various ratios and are cheap and easy to install. Here is the site I bought them from, they list many different ratio's. GM even used them from the factory in some applications so they did not have to have as many speedo drive gears in stock to reduce assembly complexity
1 - 16 of 16 Posts
