Well my power antenna finally went out I can still hear the solenoid click it just will not lift up if I pull it out it will pull back down any idea whats going on I disassembled the whole thing and cleaned it the plastic gear in the antenna seems to be fine it was working great it went down when I turned off my car then it wouldnt Go back up just down if I try to pull it up fuses are fine voltage is great Im just not sure if the motor is spinning in the direction that pushes it up
