Hey guys, I've got an incredibly confusing issue here and I've run out of ideas. Once every 5-7 times I try to start my firebird, I get a no crank no start with the only response being the starter motor gear engaging and retracting with a loud "clack". Here's the video:
This only happens every once and a while, and a couple of times that it has it would randomly decide to start after waiting for a few moments with the key out of the ignition. The battery is brand new and tested at over 12.75 volts the few times this has happened when I am at home, the old one had bad cells. I also just replaced the starter motor with a brand new one because the old one had a bad solenoid. The thing that is absolutely baffling me is the randomness and inconsistency with which it happens. I know it is not a mechanical fault with the engine, as when it does start, it starts and runs like a champ. Here's a video of it firing up the day I finished installing the new starter motor, which was only about a week ago. Only difference being is that it starts a little slower now because it was hooked up to a charger at the time:
I suspected that the alternator wasn't charging the battery but it appeared to be kicking out plenty of voltage, but I ordered a new one anyway because mine makes some strange noise and gets way too hot. Other notes to add, it seems to always start after being jumped with another running car, but seeing as doing nothing to the car and waiting a few moments has also resulted in the car going from not starting to starting, that could just be a coincidence. I also have one more video, this is of a voltmeter hooked up to my battery while trying to start the car:
Any help is appreciated and I can perform additional tests and answer any questions, thanks!
