1 - 1 of 1 Posts
VISIT OUR WEBSITE HERE FOR CURRENT PRICES
1982 - 1992 Pontiac Firebird T-Top Plastic Hatch Drip Edge Seal PAIR
This is new Camaro or Firebird 82-92 T-Top Weatherstrip molded Plastic hatch strip or drip edge seal set. These are the peices that attach to the t-top outer edge and overlaps the window. If yours seal is missing, torn or dry rotted from age, then this kit is what you need.
Specifications:
Sold as a PAIR
2 Seals to replace outer hatch seal drip edge
Direct replacement
Closest to the original seals in the aftermarket
Replaces OE part numbers: 10198352, 20453467
PLEASE NOTE: Seals made in PLASTIC. Please see 1AWSK00248 for Rubber replacements
The RED strip on molding is an adhesive strip used to help secure and seal once installed
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side the tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
1 - 1 of 1 Posts
