Sorry if this post should be in the First Gen section, but I am kinda straddling a line here - car vs engine. I found "400" stamped on the bottom of the block. On the front, passenger side just below the head, I found what looks like "?263453" (note: the first digit looks like it maybe a 6, or is a just booger in the casting) and underneath that is "YS" . At bottom of block (towards rear on driver side) is "GM-6 D N". The heads were swapped for Edelbrock Performer RPM so there are no ID numbers available on the head. I checked the ID numbers in the PPN and Wallace Racing database and found no YS 400 blocks that have an block casting number that starts with a 6 or a digit that is kind of round-looking. I threw in some picks of the car ID info along with the engine ID info.
Any help figuring out what is really under the hood of this little beastie is much appreciated.
PS I did look at the transmission pan and the shape matches the TH350 (has 13 bolts).
I found "400" stamped on the bottom of the block. On the front, passenger side just below the head, I found what looks like "0263453" (note: 02 (maybe a "C" and not an "0", or is just booger in the casting) and underneath that is "YS" . At bottom of block (towards rear on driver side) is "GM-6 D N". The heads were swapped for Edelbrock Performer RPM so there are no ID numbers available on the head.
