So i'm trying to backtrack the ignition on no spark.. and while i'm in the process of learning and exploring this points system.. I was wondering if the interlock safety system had anything to do with killing spark too alongside the starter kill.
I've already experienced the no starter turn over, but i've been bypassing that with a solo man remote switch wired to the starter.
Not sure if the bypass button under the hood is operable havent really messed with it much..
But while i'm giving this ignition points system a few more opportunities before throwing in the hei, I wanna make sure this seat system isnt screwing with me.
I got 12v at the + on the coil in ON position, tested various grounds with multimeter/battery after cleaning all ground points.. checked connectivity on the - wire going to the distributor points, and adjusted points in various ways and still see no spark or got nothing. Tested only the primary on the coil, but will the secondary, and mess with points again...
Just making sure i can rule out this pesky ignition interlock, but serves as a good "kill switch" feature too for would be theives, thanks
