1 - 4 of 4 Posts
Hello,
I have a 1970 Firebird with the face plate cut out for a newer style 1 DIN radio. Has anyone fabricated a faceplate or is there a product that will clean this up nicely.
I guess I can buy a bezel for 1970 to 1977 and cut it out cleanly for a single din.
Thanks
Chuck
Discussion Starter · #2 ·
The single din dimensions are 2" x 7". I did some researching and found this info for a radio delete plate . I ordered the radio face plate bezel and will see if I can modify it .
radio delete plate dimensions
Measurements are horizontally 8-3/4" across the top and 8-1/2" across the bottom lengthwise. Vertically the plate is 2-1/2" tall. Fits 1970-81
I just cut out a piece of aluminum and gave it a brushed finish for a singe din stereo to clean it up. I made a template first out of cardboard then transferred it to the Al.
Thanks,
I was going to use the new bezel i bought as a template and have a friend cut one out of plate steel. I will only have 1/4 of material on the top and bottom and the plastic may be too flimsy by itself so i figure I can sandwich it.
1 - 4 of 4 Posts
