1 - 3 of 3 Posts
Need a 3-31/32" hub height water pump. where can I buy one? If I use the 4-1/2" pump, what do I have to change. Crank pulley, alternator bracket, power steering? need part numbers?. any help would be appreciated.
Thanks
If you use the taller water pump I think you just use the taller pulley I don't remember the exact measurement
I would check with Franks Pontiac parts it is a Pontiac only dismantler he has a boat load of pulleys
Here is a link .
http://www.frankspontiacparts.com/
1 - 3 of 3 Posts
