421 - 440 of 460 Posts
I found a OEM fender and picked it up over at Franks Pontiac parts in the California desert.
Right now it's in Laguna New Mexico on US route 66 on it's way to Albuquerque I should get it about Tuesday.
So I have some more work to do YEAAA!!! I need a patch panel for the rear corner .
It's a good thing I already did this on the other side and know what I'm doing LOL .
Table Automotive tire Motor vehicle Wood Architecture
Water Wood Automotive tire Automotive lighting Gas
Automotive tire Wood Automotive exterior Asphalt Fender
Automotive tire Tire Bumper Road surface Automotive exterior
Air gun Trigger Automotive exterior Gun barrel Bicycle part
Discussion Starter · #422 ·
The fender is in Tulsa Oklahoma now I wished I was too lol
I found another rally wheel from a junkyard somewhere in Connecticut on eBay it looks like it was sunk into the ground about 6" and pitted badly i put some body filler to fill the pits and painted it turned out pretty good
And i have the passenger side fender blocked and done here's the pictures
Tire Wheel Automotive tire Light Tread
Wheel Tire Automotive tire Hubcap Tread
Hood Automotive tire Automotive design Motor vehicle Automotive lighting
Discussion Starter · #424 ·
Painting all 25 of the front bumper parts to get ready for assembly wish me luck
And this is only half of them the other half are already done
Wheel Motor vehicle Wood Tire Engineering
Reactions: KeyKeeper
Thanks Rick finished with the Rust-Oleum satin black
Automotive tire Motor vehicle Engineering Gas Automotive wheel system
Discussion Starter · #428 ·
I'm getting there wont be long now.
Getting pretty stoked !!!
Car Wheel Tire Vehicle Land vehicle
Wheel Tire Car Vehicle Land vehicle
Car Tire Vehicle Wheel Hood
Car Wheel Land vehicle Vehicle Tire
Looking good James, you are almost there!!!
']['exXxas']['itan
If my motor was actually assembled....we would be at the same portion of our bird build journey! Great work and really look forward to hearing this one run!
Discussion Starter · #432 ·
Roger roger
Discussion Starter · #433 ·
This is a test
Automotive tire Automotive exterior Motor vehicle Gas Automotive wheel system
I mocked up the passenger side fender with the badges and louvers just for fun and to see how it would look.
I also started stripping the paint off the oem ds fender I picked up from franks it's amazing what passes for body work.
There is almost no rust on this fender but in the usual spot where the body brace runs down the rear of the fender .
And so the work begins .
On a side note today I have a pork butt in the smoker for some pulled pork YUMMM !!!
Hood Automotive lighting Bumper Vehicle door Fender
Motor vehicle Hood Automotive tire Automotive design Aircraft
Motor vehicle Automotive tire Bumper Automotive exterior Gas
Motor vehicle Wood Automotive exterior Bumper Gas
Automotive tire Bumper Motor vehicle Automotive exterior Automotive lighting
Plant Cooking Grass Cookware and bakeware Leisure
Discussion Starter · #436 ·
Well I started putting the bumper back together what a pain in the you know what
I'm glad I have the factory assembly manual and the service manual
there sure is a certain order this bumper goes back together in.
Wheel Tire Automotive tire Motor vehicle Automotive design
Automotive tire Motor vehicle Gas Engineering Machine
Rectangle Font Parallel Art Auto part
Rectangle Font Parallel Diagram Schematic
Robert Yes I have taken a little break still doing little things every day .
Still assembling the bumper I had some more painting to do .
I found the front valance brackets one was ripped in half the other was bent out of shape
and broken on the oval hole I welded that up and bent it back into shape and then fabricated
the one for the other side, here's pictures I know everyone loves pictures LOL
Composite material Auto part Metal Concrete Font
Calipers Wood Tool Hardwood Tints and shades
White Light Azure Rectangle Material property
