1 - 20 of 460 Posts
I will start this in the morning I had to much fun today!!!
I did get a lot do today
Discussion Starter · #2 ·
I started this rebuild this last April I had to pull the front end apart to see what damage had been done
Hood Automotive lighting Vehicle Automotive tire Tire
Everything came apart pretty easy the car was originally from Texas. I am going to pull the motor and frame to paint
and i need to replace the oil pump the flywheel clutch and pressure plate
Tire Wheel Motor vehicle Automotive tire Vehicle
Hear is the valve cover painted
Laptop Netbook Computer Personal computer Gadget
The driver side frame was bent the bumper support was at almost a 90 degree angle
Motor vehicle Automotive tire Bumper Automotive exterior Wood
This is after I straightened the frame with a porta power .
I took measurements per the drawings and everything was with in tolerance
Tire Wheel Automotive tire Vehicle Motor vehicle
Pulled the drive shaft and headers to get read to pull the motor next week some time
Tire Wheel Automotive tire Hood Motor vehicle Automotive tire Motor vehicle Bumper Gas Automotive exterior
I will up dates as it progresses
Found a hole in the passenger side rear floor pan where the emergency brake cable wore thru
Brown Wood Amber Fixture Gas
I have been getting parts for the last 9 months
Here are some parts pictures Oh and the engine is ready to pull
Motor vehicle Vehicle Gas Machine Classic
The radiator support
Motor vehicle Wood Gas Shipping box Machine
Suspension parts
Shelf Wood Font Bookcase Shelving
Valance and headlight
Bookcase Shelf Wood Bumper Automotive exterior
Hood hinges and front end parts
Musical instrument Shelf Wood Chair Floor
took me three days clean mask and paint this black and then clear coat.
Ceiling fan Mechanical fan Cross Art Wood
And a shelf full of blasted and powder coated parts
I got powder coat setup from Harbor freight it works pretty good
Machine Electrical wiring Electrical supply Shelf Wood
Moving right along.
Admin - Firebird lover
nice progress and your parts look great.
Reactions: firebird_madness
Discussion Starter · #8 ·
Thank you Layne I am HAVING way to much fun
It does look like your having to much fun
BucketHead
I'll be keeping watch on this Bird!
Discussion Starter · #11 ·
I got some small things done I rebuilt the back brakes powder coated the backing plates and the drums new shoes and springs
Tire Automotive tire Wheel Vehicle brake Tread
Pulled the power steering pump apart and powder coated that but when I cooked that it melted the solder in the reservoir tank
I will JB weld it from the in side to make sure it won't leak
Motor vehicle Bumper Gas Automotive exterior Wood Wheel Automotive tire Tire Automotive wheel system Gas
Got the drive shaft blasted ant painted with new u joints
Tool Nickel Composite material Auto part Musical instrument
And a couple of pictures of the powder coating setup
Wood Shelving Gas Electrical wiring Hardwood Wood Audio equipment Gas Electronic instrument Machine
Discussion Starter · #12 ·
Well its been a while so here is a update I pulled the engine out and pulled it apart
Tire Wheel Automotive tire Motor vehicle Automotive lighting Automotive lighting Motor vehicle Automotive design Art Gas
I found some problems the valve springs were not matched to the cam and dished
A lifter and roached a lobe on the cam on closer inspection the cam had wear on some
of the other lobes. This was probably caused by not using a oil high in zinc MY BAD
Wood Fashion accessory Metal Darkness Body jewelry Liquid Automotive lighting Fluid Bicycle part Bumper
Automotive exterior Trunk Bumper Motor vehicle Gas
I rebuilt built the heads and picked a comp cam kit K51-222-4 with new springs.
I used this stuff phosphoric acid It turns iron oxide (rust) to iron phosphate a hard
protective coating ready to be painted
Automotive exterior Trunk Bumper Motor vehicle Gas Land vehicle Motor vehicle Wood Vehicle Gas
I am also going to pull the rest of the engine apart because of all metal I had rolling
around in there. I checked the cylinder bores with inside micrometers and came up
with 4.122 about .002 wear remember a hair measures .003 and maybe .001 taper
from top to bottom. So I am replacing the rod main and cam bearings and new pistons
I have to replace the rear main seal anyhow.
And I want thank every one for all the help here at FBN
Wood Gas Hardwood Machine Metal
Well I have all the engine parts painted with dupli-color ceramic engine enamel
I've heard good things about this paint
Hood Automotive lighting Vehicle Automotive design Motor vehicle Automotive lighting Home appliance Automotive design Bumper Fender
I have the cam and cam bearings installed and the crank polished and reinstall
With new bearings. I made a cam bearing removal- installation tool at work on the
Lathe it works really good I found one of the old cam bearings was installed wrong
and showed abnormal wear and I have some extra help here
Wood Tool Gas Metal Auto part Automotive tire Motor vehicle Automotive exterior Bumper Automotive wheel system
Wood Gas Automotive exterior Bumper Auto part Automotive tire Wood Motor vehicle Bumper Automotive exterior
Discussion Starter · #14 ·
I polished the crank my self with 600 emery and then finished with 1500 you wrap it around and put masking tape around it
then 2 wraps with a leather shoe string I used a old dryer belt and pull it back and forth
Motor vehicle Auto part Automotive design Automotive wheel system Machine
Nice Job James!!! Keep up the good work, wish I could do all that work to my engine, just dont have the knowledge with the internals.
Thanks for the words of encouragement I rebuilt this motor about 25 years ago kinda been doing this all my life but its fun when its done
Discussion Starter · #18 ·
She's going to be a sweet ride when your finished.
Thanks Bill you know i think she needs a name Ive never named her and it not going to be brown any more
1 - 20 of 460 Posts
