[Resolved] - Hydraulic clutch slave cylinder help - Resolved Drivetrain Issues - Firebird Nation
2 replies to this topic
#1
  • 9 posts
Posted 08 August 2006 - 01:19 PM
Hi there, a few days ago I lost my clutch and saw that all fluid had leaked out so began inspecting the hydraulic system. Turns out the slave cylinder (or release cylinder) housing broke where the little metal clip clips into and holds everything inside.
The car is a 87 Trans Am with the 305 tpi.
The Haynes manual says you have to replace the entire hydraulic assembly (master cylinder, lines, slave cylinder and fluid compartment all in one sealed assembly), and I can't find one in any junkyards and GM wants over $300 for a new one (part 12527718). Seems way too much for such a simple problem. Anyone knows if its possible to replace only the slave cylinder, or even rebuild it? Thanks any help would be greatly apreciated!
#2
  • 9 posts
Posted 10 August 2006 - 06:33 AM
problem solved, turns out you can replace just the slave cylinder.
#3 FBN Firebird Nation
Posted 10 August 2006 - 10:12 AM
Good to hear you got it fixed. :14dunno:
