i have a problem, and i need some help.
#21
Posted 17 May 2015 - 07:34 PM
#22
Posted 18 May 2015 - 11:33 AM
i have a '96 3.8 birdy, and the service engine light is on and whenever i power wash it or we get a medium to heavy rain, i start it up, and the car starts shaking and it doesnt run right for about 30 seconds, and whenever this happens the service engine light blinks, then after about 30-60 seconds, it just runs normal again, does any1 know what's going on? thank you.
I've had the exact same problem before on 2 ocassions. What's (more than likely) happening is water is leaking through the cowl weatherstripping onto your ignition coils. I pulled the code during the second time it happened and it was for cylinder #2 misfiring. Turns out water was dripping directly onto the ignition coil for #2. Happened while I was basically sitting still during heavy rain on both ocassions, still haven't had it happen after washing it though.
1999 Pontiac Firebird (V6) "Fiery Bird of Preyz" (Arctic White) dark blue, purple, and black Phoenix on hood, Flowmaster 80 series muffler, Magnaflow high flow catalytic converter, K&N air filter, MSD 8.5mm Super Conductor ignition wires, mail order tune from PCMforless
2000 Pontiac Firebird Trans Am Firehawk #0328 "Black Betty" (Black) 1 3/4" stainless steel long tube headers (brand unknown), 3" stainless steel y-pipe (brand unknown), 3" Magnaflow stainless steel cat-back exhuast with 3" twin dual tips, K&N air filter, SLP air lid, free ram air mod, EGR delete, red interior LED strip footwell lights, 17"x9.5" chrome C6 Z06 replica rims
