High Beams not working at all. - All Things V6 - Firebird Nation
3 replies to this topic
#1 Kire
Kire
  • 16 posts
  • First Name:Kire
  • City:Las Cruces
  • State or Province:NM
  • Engine: 3.8l V6
  • Transmission: 4-Speed Slushbox 4L60E
Posted 2 weeks ago
I have a 1998 Pontiac Firebird V6 and the high beams do not come on at all when I pull the turn signal lever towards me. There is no "reaction" and is extremely flimsy. My turn signals and all other lights work on just fine when turned on but there is no indication on the dash that my high beams are on whenever I attempt to turn them on.. I have looked at other forums about an "adjustment" you can do to them but the pictures are unavailable and I'm lost on how or where to start. Any help is greatly appreciated!
Sent from my SM-A716U using Tapatalk
#2 JOE68
JOE68
  • 841 posts
  • First Name:Joe
  • City:waterford
  • State or Province:PA
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: ST300
Posted 2 weeks ago
you may need to replace the switch
#3 Kire
Kire
  • 16 posts
  • First Name:Kire
  • City:Las Cruces
  • Engine: 3.8l V6
Posted 2 weeks ago
I found 2 different switches on my favorite website. One looks like it comes with a little metal beam while the other one doesn't. Does this one work?8c5550089f3819aedb201ce41f7bea8a.jpg
#4 Injuneer
  • 14126 posts
Posted 2 weeks ago
Looks like it.
http://shbox.com/ignsw/column2.jpg
Shoebox has a repair procedure for the ignition switch (93-97, 98 should be similar), which is held on by the same screws.
http://shbox.com/ign...witch_repl.html
