COLD AIR INTAKE - All Things V6 - Firebird Nation
COLD AIR INTAKE
4 replies to this topic
#1 giveherthebird
giveherthebird
  • 34 posts
  • First Name:Ryan
  • City:somerset
  • State or Province:MA
  • Engine: v6
So i have been thinking of doing a custum intake. i have the 3.8, just so you know. ive looked at the stuff on sale and i dont really want a intake thats under my car, i feel like it will suck up water. so what i want to do is make a ramp kind of thing coming from the nostrils too the intake. any thoughts would be great.
#2 Injuneer
  • 14021 posts
A properly installed CAI in the driver side inner fender will not suck in water.  Every successful CAI for the 93-97 cars is designed that way.  I ran one for several years with no problems.
If you want to pull air from under the front bumper,consider adapting the air box from the 98-02 LS1 V8 cars.  The box sits in front of the throttle body on the radiator support, and pulls air out of the bottom.  There is a “free mod” that opens up the slot on the bottom of the box and a duct system made by Fast Toys in Canada that sticks down toward the road.
The only complication with the LS1 box would probably be the fact the V6 throttle body has that weird angle.
#3 giveherthebird
giveherthebird
  • 34 posts
  • First Name:Ryan
  • City:somerset
  • Engine: v6
OK THANK YOU
#4 Injuneer
  • 14021 posts
To use the LS1 V8 airbox, you will need to check to see if there are any differences in the V6 hood or radiator support.  Then there is the aforementioned issue of the V6 throttle body angle.  Can you cobble up a coupling from the airbox outlet to the throttle body"  The V8 throttle body is "straight", not angled downward.  I am just throwing out thoughts here, since no one else seems to want to help.  The CAI topic has been discussed by numerous 3.8L V6 owners, so I am surprised they are not helping out here.
If the V8 airbox works, you will need to open up the narrow slot in the bottom, to allow more air flow.  I have helped V8 owners do that.  I looked for the Fast Toys duct, but apparently they no longer make it.  SLP has a similar duct that inserts in the enlarged slot on the bottom of the airbox and extends downward in front of the radiator baffle.
https://www.ecklers....nt=All Products
When you mention "the nostrils" are you talking about the indentations in the lower part of the front bumper, or the two slots in the seam between the hood and the upper bumper edge?
#5 tommy vercetti
tommy vercetti
  • 176 posts
  • First Name:Tommy
  • City:desenzano del garda
  • State or Province:Other
  • Country:Italy
  • Engine: 3.8
  • Transmission: t 5
Posted 5 days ago
i do have some home made cold air intake, k&n cone filter down into the bummper / fender , connected to throttle body by a flexlible tube and an aluminum curve.
it's similar to the cheap kits you can find on ebay.
i can't honestly tell there has been much improvement.
i'll post a pic later.
best solution i think would be the flow pac linked by injuneer , but it's mega expenisve. depends on the budget you have.
