Fuel Pressure - Third Generation Pontiac Firebird (1982 - 1992) - Firebird Nation
Fuel Pressure
3 replies to this topic
#1 kens727
kens727
  • 10 posts
  • First Name:Kenneth
  • City:Milton
  • State or Province:DE
  • Interests:Cars Airplanes
  • Year: 1982
  • Engine: 5L
  • Transmission: Automatic
Posted 4 weeks ago
I have a 1982 Trans Am that I restored and love. I had it running great for about 6
months and now it has developed a really bad lag. I step on the gas and it about dies before it finally accelerates. It has dual TBI and I suspect fuel pressure. I can not find any information on the pressure the fuel pump should put out before it is regulated. The fuel pressure at the TBI is 10 psi . The system is the stock cross-fire injection system and the TPI checks out OK and I cant find a major vacuum issue, any ideas?
#2 ZumpTA
ZumpTA
  • 2236 posts
  • First Name:Tony
  • City:Holiday
  • Transmission: 6-Spd
Posted 4 weeks ago
I think 9-13 stock (but ideally 15psi) is where you want to be, so 10 sounds about right.  Maybe clean the "injectors", could be a blockage?
-- Jeremy S. Anderson
-- Wernher von Braun
#3 kens727
kens727
  • 10 posts
  • City:Milton
  • Year: 1982
  • Engine: 5L
Found problem, a crushed fuel line. Pressure was good but low volume. I now have to find new fuel sending unit which includes pluming out of tank. I found plenty for 85 but none for 82. Do you know the difference between these units for example the Dorman 692-137 for an 85 and what I need, they look the same but give no specifics in the description and looks don't always matter.. Thanks for the help.
#4 Injuneer
  • 13959 posts
Do you need the complete sending unit including the pump?
Hawks has a refurbished unit without the pump.  Very expensive, but appears part of the price is a core charge, requiring return of your old part in decent condition.  Shows unavailable, but they might have got another one in.  Worth a call.
.https://www.hawksmot...it-refurbished/
They also have the TBI (low pressure) fuel pump.
https://www.hawksmot...el-pump-kit-gm/
