Alternator not charging - circuit board? Ignition Switch? - Electrical - Firebird Nation
3 replies to this topic
#1 Jon S
Jon S
  • 2 posts
  • First Name:Jon
  • City:Macungie
  • State or Province:PA
  • Make: Firebird
  • Model: 350HO
  • Transmission: Manual
I am trying to resurrect my 69 firebird that I have had in my garage for 39 years. It runs great but wont charge. I have tried alternator and external regulator replacement, wiring checking under hood etc, but still not charging. I had car at restoration place for work; they re-did some mechanical items for me and tried to figure out the electrical issue, but are not able to complete the electrical evaluation/repair for me for some reasons due to covid they say. Anyway, I believe the issue is dash area; circuit board, ignition switch, maybe even wiring under dash (?). I have the factory stacked gauges, factory tach. Tach works, headlights work, but none of the lights (gen) in the dash work. Gas gauge and horn doesn't work either. I get the car back early next week and am thinking of taking a look at it myself to see if I can repair it. I was hoping some people here have had the same issue and could shed some insight. Has anyone ever replaced their circuit board or ignition switch? Wondering what the difficulty level is; seems like wouldn't be too challenging, but I haven't looked at it yet.
Thanks for taking the time to review my issue,
Jon
#2 JoePeek
JoePeek
  • 1476 posts
  • First Name:Joe
  • City:Westfield
  • State or Province:IN
  • Year: 1971
  • Engine: 455 HO
  • Transmission: 4 speed
I would first confirm the alternator is putting out around 14 volts when the engine is running using a voltmeter touching the main big wire nut on the back of the alternator to ground.
Then check the voltage with the engine running at the battery. With the engine off, the battery should read somewhere around 12 volts With the engine running it should check around 14...maybe 13.5. Is the wire running from the back of the alternator to the main starter + connection in good condition? Even check the voltage at the main starter connector with the engine running. If about 13.5 to 14.5 volts are not making it to the + battery when the engine is running, it will not charge.
#3 JOE68
JOE68
  • 808 posts
  • First Name:Joe
  • City:waterford
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: ST300
beyond what Joe said , bad grounds can cause goofy probs.    corrosion in connectors or damaged wires could be cause too.   I;ve found that the fuse contacts on mine needed cleaning even tho they looked fine.    I could wiggle fuse around and suddenly it worked
#4 Jon S
Jon S
  • 2 posts
  • First Name:Jon
  • City:Macungie
  • Make: Firebird
  • Model: 350HO
Thanks for the input guys, I will go over every connection and clean and make sure good connection.
