1970 catalina - General Engine (Non-Gen Specific) - Firebird Nation
1970 catalina
7 replies to this topic
#1 70catalina
70catalina
  • 2 posts
  • First Name:Pat
  • City:Cincinnati
  • State or Province:OH
  • Year: 1970
  • Model: Catalina
  • Engine: 350 pontiac
  • Transmission: Auto 350
Posted 2 weeks ago
Please Help....i kno its not a firebird but its hard to find pontiac help...i have a 70 catalina with 350/350 combo and it seems sluggish after initial take off but once going its not too bad but not great and i was getting a knocking or pinging sound with vacuum advance hooked up but not with it off....where do i start to find problem...any help would be greatly appreciated thanks in advance
#2 JoePeek
JoePeek
  • 1467 posts
  • First Name:Joe
  • City:Westfield
  • State or Province:IN
  • Year: 1971
  • Engine: 455 HO
  • Transmission: 4 speed
Posted 2 weeks ago
I would start with the ignition system. Make sure the timing is set around 8° - 10° with the vacuum advance hose disconnected. Give the engine a rev with the timing light hooked up and make sure the timing mark advances up off the scale, then comes back.
#3 sea dog
  • 3110 posts
Posted 2 weeks ago
Fuel system could be causing problem also. If gas in tank is old, drain the gas. New inline fuel filter and filter at carb inlet. Being car is 50 years old, I'm betting filter sock in gas tank is pretty clogged up too.
Unfortunately,  gas tank must be dropped to inspect & replace filter sock. This would be a good opportunity to inspect inside the gas thank for rust & crud.
Carb could use a good cleaning and rebuild also. A good cleaning doesn't mean spraying carb cleaner on outside of carb. It means disassembling carb, soaking carb body in carb cleaner, installing rebuild kit and adjusting carb settings.
#4 D Bergy
D Bergy
  • 21 posts
  • City:Grand Rapids
  • State or Province:MN
  • Interests:Cars, Alternative medicine, Practicing Guitar
  • Year: 1967
  • Make: Firebird
  • Model: Convertable
Posted 2 weeks ago
In 70 they still had some pretty high compression ratios. If the other good suggestions dont do it you may just need higher octane fuel. Do you know what the compression ratio is?
My 71 Mach 1 was something like 10.5 to 1. No way that wasnt going to ping without help.
Dan
#5 70catalina
70catalina
  • 2 posts
  • First Name:Pat
  • City:Cincinnati
  • Year: 1970
  • Model: Catalina
Posted 2 weeks ago
It has new carb 1406....new performer 2156 intake.... new distributor but is factory style points and both fuel filters are new an for the timing it seems to like between 9and12 so im guessing fuel and tuning would be issue and i can only get 93 octane and add booster near me so not exactly sure what octane im getting but what would be ideal octane?
#6 JoePeek
JoePeek
  • 1467 posts
  • First Name:Joe
  • City:Westfield
  • Year: 1971
  • Engine: 455 HO
Posted 2 weeks ago
Have you made any adjustments to the carb ?  I would run the idle mixture screws on the rich side of the good range, a little extra fuel will help against ping. Is the distributor the factory part number. Every distributor part number has a specific timing curve matched to the engine, just like every carburetor has specific jets and metering rods selected to work well with that engine. When you replace your factory carb with an aftermarket carb, there is a good side and a bad side. The good side is that you have a new carb in brand new condition, the down side is that you lost the "tune" that the factory carb had that matches you engine. The same thing with the distributor, the timing curve in the distributor that came in your engine, has a curve matched to your engine, gears, cam, etc, on the mechanical curve on the vacuum advance. Sounds like you need to dial in the carb and timing since you changed the carb and distributor.
#7 sea dog
  • 3110 posts
Posted 2 weeks ago
According to the Motor 1971 service manual, 350 Pontiac motor for 1970 had 8.8 to 1 compression. So it should run fine on 93 octane gas. You might even be able to run mid grade gas without knock or ping also.
#8 JOE68
JOE68
  • 787 posts
  • First Name:Joe
  • City:waterford
  • State or Province:PA
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: ST300
did you adjust the dwell when you put in dist ?
