1996 Firebird Swap - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
1996 Firebird Swap
2 replies to this topic
#1 Clouder
Clouder
  • 1 posts
  • First Name:Michael
  • City:Marion
  • State or Province:IN
  • Engine: 3800
  • Transmission: Manual 5
Posted 5 days ago
I have a old school 350 from a donor gmc. I was told it should just drop right in with tweaks needing to be done to the computer. Any help on this would be appreciated
#2 Injuneer
  • 13817 posts
Posted 5 days ago
It may not "drop in".  The 1996 Firebird has two different K-member (engine support) configurations, one for the Gen 2 SBC (LT1) V8 and one for the 3800 V6.  Probably need to replace the K-member, beef up the front springs, etc..  The T5 tranny in the 96 is not strong enough to reliably handle decent power/torque from a V8.  That's why GM never put the T5 behind the L98 350 engines in the third Gen F-Bodies.
And no way you can run a Gen 1 SBC with a PCM from a 1996 3.8L V6.
#3 ZumpTA
ZumpTA
  • 2112 posts
  • First Name:Tony
  • City:Holiday
  • Transmission: 6-Spd
Posted 5 days ago
Define "old school".  To me and likely everyone else, old school means carbureted.  Even with the older TPI engines, I highly doubt the 3800 ECM would work.  Drop right in?  No.  Not even close.  Easier than an LS swap into a mustang or miata, but abandon all hopes of "drop right in".  You'd at a minimum need a v8 k-member, suspension upgrades, brake upgrades, the appropriate computer (obd1 or none at all).  Not sure the 5 speed is up to the extra torque either.
-- Jeremy S. Anderson
-- Wernher von Braun
