V6 3.1 1992 Firebird not running. - Third Generation Pontiac Firebird (1982 - 1992) - Firebird Nation
7 replies to this topic
#1 ChrisM
ChrisM
  • 4 posts
  • First Name:Chris
  • City:Nederweert
  • State or Province:AL
  • Country:Netherlands
  • Year: 1992
  • Engine: 3.1 v6
Hello, my name is Chris and I'm from the Netherlands. I need some help.
My Firebird V6 from 1992 wil not start.
It has no malfunction codes, it has spark, fuelpump runs, but it wil not run.
It also does not start on brakecleaner.
I already put in new sparplugs, new ignition wires, new rotor, new ignition cap, new ignition module, new IAC valve, new TPS sensor, new Map sensor, new Fuel pump, new ignition coil, new battery.
Stil not running.
There is an aftermarket alarm in the car could this be the problem, or is there an other thing I should check.
Thank you for reading.
#2 Injuneer
  • 13817 posts
Are you aware the vehicle has a Vehicle Anti-Theft (VATS) system?  Do you have an Owners Manual showing operation of the system?
Have you scanned the ECM (computer) for trouble codes?
Have you checked the fuel pressure?
#3 ChrisM
ChrisM
  • 4 posts
  • First Name:Chris
  • City:Nederweert
  • Year: 1992
  • Engine: 3.1 v6
Thank you for replying.
I checked for codes, but there are non.
I checked for fuel by using the ceck valve on the intake manifold. At the rear of the itake.
It could be the VAT systhem. How can I check this.
#4 sea dog
  • 3089 posts
Does your security light come on when you turn key on? Then go out after several seconds? This is normal procedure for security system. If security light stays on engine won't run because fuel injectors will not open & spray fuel. Good vats write up at  http://www.shbox.com
However, since you sprayed flammable liquid into intake & engine wouldn't run, I suspect an ignition problem.
#5 Injuneer
  • 13817 posts
Unanswered questions:
Do you have an Owners Manual showing operation of the (VATS) system? (These may be available online as digital files, from GM)
Have you checked the fuel pressure? (or did you just depress the Schrader valve on the test port to see if fuel came out?)
#6 ChrisM
ChrisM
  • 4 posts
  • First Name:Chris
  • City:Nederweert
  • Year: 1992
  • Engine: 3.1 v6
Posted 4 days ago
I checked the ignition, its okay.
Everything has been replaced with new parts.
Securety light goes out while starting.
When I clean all the sparplugs it wants to start, it runs and then stops.
When I look at the sparkplugs after that they are wet.
Could it be getting to much fuel.
I have spark, fuel, compression, but not running....
Pfffff what can it be.
#7 Injuneer
  • 13817 posts
Posted 4 days ago
If the spark plugs are soaked with wet fuel, to the extent that they can't fire, there has to be a problem with too much fuel.  Are all the plugs wet, or just a few?
Could be a problem with excessive fuel pressure, or the injectors being stuck open.  But you apparently don't want to tell me about an actual fuel pressure test.  With pressure gauge in place, turn the key to "run" (not to "start") and watch how the fuel pump primes the system.  What is the pressure when the fuel pump shuts off?  How fast does fuel pressure drop (which may indicate leaking injectors).  When the engine does start (after cleaning the plugs), what is the fuel pressure?
There is also a possibility the plugs are not firing and no fuel is being burned.  You indicate "I checked the ignition, its okay.".  Have you pulled a plug wire, held it near a ground and actually observed the presence of a spark while the starter is cranking the engine?
Another possibility - Could also be the coolant temp sensor indicating a very low coolant temperature.  The ECM enriches the A/F ratio on cold start.  If the coolant temp sensor is indicating an unrealistically low temperature, it could be flooding the engine.  You would need an OBD-1 scanner with the ability to read real-time ECM data to check this possibility.
#8 ChrisM
ChrisM
  • 4 posts
  • First Name:Chris
  • City:Nederweert
  • Year: 1992
  • Engine: 3.1 v6
Posted 4 days ago
I will start checking everythinh you wrote down.
