Brake issue - Second Generation Pontiac Firebird (1970 - 1981) - Firebird Nation
Brake issue
9 replies to this topic
#1 edteach
edteach
  • 219 posts
  • First Name:Jim
  • City:Bentonville
  • State or Province:AR
  • Interests:Shooting and antiques
  • Year: 1980
  • Engine: 301
Posted 3 days ago
I noticed the last two times I took the FB out the brake peddle goes down a long ways and is hard. I have to put a lot of pressure on it to stop fast. Going slow it seems to work ok but the peddle goes down more than before. I checked the BF reservoir and its full. No leaks. Not sure what it the issue. I can run it to a brake shop but if I can figure out the issue myself all the better. Thanks for any help
#2 ZumpTA
ZumpTA
  • 2088 posts
  • First Name:Tony
  • City:Holiday
  • Transmission: 6-Spd
Posted 3 days ago
Hard brake pedal is most often a vacuum (lack of) issue.
-- Jeremy S. Anderson
-- Wernher von Braun
#3 edteach
edteach
  • 219 posts
  • First Name:Jim
  • City:Bentonville
  • Year: 1980
  • Engine: 301
Posted 3 days ago
Thanks. I will check the vacuum lines coming off the PB unit.
#4 JOE68
JOE68
  • 768 posts
  • First Name:Joe
  • City:waterford
  • State or Province:PA
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: ST300
Posted 3 days ago
if your rear brakes aren't adjusted properly it will cause excess travel and poor braking
#5 edteach
edteach
  • 219 posts
  • First Name:Jim
  • City:Bentonville
  • Year: 1980
  • Engine: 301
Posted 2 days ago
So I did a quick look at the vacuum lines from the PB and I don't see anything obvious. I was going to start it and run some eather to see if there is a leak. but what I did find is one of the long vacuum lines from the cruise control goes along the fire wall and then hangs just under the AC compressor hooked to nothing. Where does this line go? I could not see any place it was obvious to hook in. Thanks for any help
#6 b_hill_86
b_hill_86
  • 34 posts
  • First Name:Brian
  • City:Toledo
  • State or Province:OH
  • Year: 1977
  • Engine: Pontiac 400
  • Transmission: 4 speed
Posted 2 days ago
That line goes to the servo (diaphragm) thats mounted on the firewall (assuming you have a 400) which you appear to be missing.
#7 edteach
edteach
  • 219 posts
  • First Name:Jim
  • City:Bentonville
  • Year: 1980
  • Engine: 301
Posted 2 days ago
Mine is a 301. So why would this line be hanging there? Is this an open vacuum line? If so I should remove the line and put in a cap?
#8 b_hill_86
b_hill_86
  • 34 posts
  • First Name:Brian
  • City:Toledo
  • Year: 1977
Posted 2 days ago
Its still for the servo. I forget where a 301 servo is mounted. On the intake if I remember right. There is no vacuum on that line unless the cruise control is engaged so it shouldnt cause any harm.
Since you dont appear to have a servo your cruise obviously wont work so if youd like to remove the cruise from the vacuum system there is only one line running from the B port on the transducer over to your carburetor most likely. You could remove that and cap the port on the carb and wouldnt have to worry about any leaks involving the cruise system
Edited by b_hill_86, 2 days ago.
#9 myk74
myk74
  • 374 posts
  • First Name:Mike
  • City:Bryan
  • Year: 1974
  • Engine: 350
  • Transmission: TH400
Posted 2 days ago
Check that check valve in the booster too. I have had those restrict vacuum before.
#10 edteach
edteach
  • 219 posts
  • First Name:Jim
  • City:Bentonville
  • Year: 1980
  • Engine: 301
Posted A day ago
The vacuum check line is fine, I removed the hose and capped the entry point to the cruise. I found one of the cluster going to the breather that did not have a line on it. Just a nipple coming out of the cluster so I capped it. Nothing else I see. Now have to take it for a drive to test it.
