Hinges
#1
Posted 08 September 2020 - 09:42 AM
Has anyone replaced the torsion springs for the trunk with gas shocks or better. Thanks in advance.
#2
Posted 09 September 2020 - 11:16 AM
Last time I checked NPD & Classic industries had 2nd gen door hinges. Repo of course. Other sources have pin & bushing sets to fix the hinges.
Do a google search for 2nd gen f-body door hinges.
#3
Posted 09 September 2020 - 02:54 PM
The trunk hinges are in bad enough shape that i will need to replace them.
GJSZ
#4
Posted 10 September 2020 - 07:50 AM
You can buy hinge pin kits in the "help" section of your FLAPS. Check around on the Pro Touring forums for the strut use for the trunk. Are your trunk hinges rusted?
John Paige
Lab-14.com
#5
Posted 10 September 2020 - 08:21 AM
The trunk hinges are pitted around the bushing area. The bushings themselves have seen better days. The attachment welds are pretty bad looking. Like a novice replacement. The lock for the torsion rod is soft and twisted and one torsion spring broke in two in the middle.
Other than that, they are fine! ;D
My thinking is, if I am going to replace I might as well look for an improvement for hinging and release.
Thanks for point in a good direction!
GJS
#6
Posted 3 weeks ago
Problem may not be the hinges but the door. Its plastic. I cant find drivers doors in nany junk yard in the country that vare not drooping. Finally saw a YouTube vid where the guy builds METAL braces inside the door and bolts the hinges to that,
#7
Posted 2 weeks ago
That's a 4th gen problem. His '70 door is all steel (although there were plastic bushings in the door hinges.
John Paige
Lab-14.com
