It will die at idle when under 60 degrees - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
5 replies to this topic
#1 Jaden_Snowman
Jaden_Snowman
  • 14 posts
  • First Name:Jaden
  • City:layton
  • State or Province:UT
  • Model: Trans am
  • Engine: Lt1 5.7L
  • Transmission: Manual, 6 gears
So I went out to start my car and do my morning errands. I started the car and all seemed normal, but after about 10-15 seconds it started to sound weird. Then the rpms started to drop and drop and drop until it died. I can rev through it but the car still shakes a lot more then normal. I have been driving my car the exact same way for the past 2 months (putting the same fuel in 88 clear, not Reving it hard, just daily driving) and have had no issues. It only started when we got the first cold morning of the season (under 60 degrees Fahrenheit) I got frustrated but was also in kinda a rush so I just took my truck. After getting back it was about 75 degrees outside and I no longer had the issue.
Next morning I go to test so see if there is still the issue and it happened again. I grabbed my fuel pressure gauge from my garage, put it on and the issue cleared up. (I was about at perplexed as I ever have been in my life)
Next morning it was a little bit warmer (70ish) and I no longer had the issue. Please help!!!
Oh and the fuel pressure primed to about 43 and started to bleed off to zero with in 2 minutes and then while running was at 38 is that normal?
My dad thinks its the fuel pump
#2 ZumpTA
ZumpTA
  • 2088 posts
  • First Name:Tony
  • City:Holiday
  • Transmission: 6-Spd
Please correct your year in your profile.  You list it as a 2000, but put 93 lt1 in there too.  LS1 and LT1 are completely different animals.
If it's a 93, 2 things to try.  One, jump the top two connectors at the top right of the ALDL port (right knee) and turn the key to ON/RUN (no start).  Fans should kick on and the service engine/check engine light will begin flashing codes.  First code is always a 12.  One flash, pause, 2 flashes.   Note any codes.  If there are none, 12 will repeat.  When done, key off, remove jumper wire.
Secondly, when it doesn't want to start, watch your RPMs while cranking.  They should raise to about 150-200.
When an engine is running rough, "throttling through it" isn't wise.
Fuel pressure sounds fine, but it may need viewed while under load.
-- Jeremy S. Anderson
-- Wernher von Braun
#3 Injuneer
  • 13772 posts
Fuel pressure should prime to at least 40 PSI, but should not bleed down that fast.  Something is leaking,,,, 1) check valve in fuel pump, 2) an injector, 3) fuel pressure regulator, 4) a fuel line including the flex line in the tank.  Running, at idle, the pressure should be 43.5 PSI with vacuum line off the fuel pressure regulator (GM accepts range of 41-47 PSI), and should drop about 8 to 10 PSI below the “no vacuum” value when you reattach the vacuum line.
Sounds like you may have a sticking injector when it’s cold, or maybe the ECM is getting a wrong temperature from the coolant temp sensor.  The ECM adjusts the cold start A/F ratio based on coolant temp.  Have you scanned for codes?
You should correct your signature info - appears your car is a 1993, but under “YEAR” you show 2000.  Might confuse people who don’t pick up the “93” under “MAKE”.
  • tom99 likes this
#4 Jaden_Snowman
Jaden_Snowman
  • 14 posts
  • First Name:Jaden
  • City:layton
  • Model: Trans am
  • Engine: Lt1 5.7L
Sorry about the confusion I didn't realize i did that, haha.
I read the codes and got only got nothing other then 12, when cranking it does raise to about 200.
I think that I have a leaky Schrader valve when ever I put the gauge on to read the pressure the issue clears up. On my way to auto zone!
#5 Injuneer
  • 13772 posts
Try cycling the key rapidly to “run” several times before turning it to “start”.  The may reduce the effects of the rapid pressure loss after the pump primes and shuts off.
Attaching the pressure gauge to the Schrader valve may allow air bubbles to escape.
#6 Jaden_Snowman
Jaden_Snowman
  • 14 posts
  • First Name:Jaden
  • City:layton
  • Model: Trans am
  • Engine: Lt1 5.7L
Posted 3 days ago
Well after a week I havent had the issue. Seems like the did the trick!!
Thank you all!!!
