Fuel sender putting out 40 M ohms - Second Generation Pontiac Firebird (1970 - 1981) - Firebird Nation
3 replies to this topic
#1 msammy93
msammy93
  • 188 posts
  • First Name:Michael
  • City:Hamilton
  • Year: 1981
  • Engine: Chevy 400
  • Transmission: TH400 MVB
Posted 4 days ago
So the fuel sender is putting out 40 M ohms. I am assuming this means mega ohms.
Does this mean the sender is bad? Or just stuck?
Fuel tank was empty and leaning up sideways for a week while I was changing the lead springs and rear axle.
I did change the fuel gauge out thinking it was bad and it's still pegged past full but the the sender is not reading open loop like it would with a broken wire.
#2 ZumpTA
ZumpTA
  • 2041 posts
  • First Name:Tony
  • City:Holiday
  • Transmission: 6-Spd
Posted 4 days ago
With a full tank the sender should should have an equal resistance to the gauge.  If the guage has 100ohm resistance, and you're seeing 40Mohms from the sender, the the guage thinks the tank is 400,000 times fuller than full.  Seeing as it's not infinite resistance, you're correct, not a broken wire.  Sounds like it was working before it sat, so I would guess the resistor board on the sender needs cleaning.  It could have corroded or oxidized or something when exposed to air.
-- Jeremy S. Anderson
-- Wernher von Braun
#3 msammy93
msammy93
  • 188 posts
  • City:Hamilton
  • Year: 1981
  • Engine: Chevy 400
Posted 4 days ago
The resistance at the gauge is the same as the resistance at the sender. It was working prior to me removing the tank. Seems like I need to pull the sender out and clean it like you said.
#4 fireforeffect
fireforeffect
  • 27 posts
  • First Name:Jason
  • City:Sykesville
  • State or Province:MD
  • Year: 1978
  • Model: Trans Am WS6
Posted A day ago
Went thru this exact same issue a few weeks ago and my gauge would bounce back and forth as soon as the fuel dipped below full. Narrowed down the problem to the sender, the resistor wasn't working correctly and drove the needle all the way to the right past full despite the continuity showing it was doing what it should be doing. Replaced w/ a quality part (sock on my original pickup was falling apart too) and gauge reads as it should and stops at Full when filled. I had several folks tell me my gauge was bad, it needed to be replaced... including a respected Pontiac only parts guy in Frederick, MD. But replacing the gauge is the most intensive fix and in this case the symptoms are telling you it isn't the gauge...
Edited by fireforeffect, A day ago.
