Transmission question - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
6 replies to this topic
#1 Tabbedout90
Tabbedout90
  • 5 posts
  • First Name:Brandon
  • City:Cache
  • State or Province:OK
  • Interests:Gm cars tinkering
  • Engine: Lt1 5.7l
Posted 2 weeks ago
So I have a 95 firebird formula with an automatic trans 3rd and 4th gears are out in it but from what I have read only the 95 lt1 4l60e transmission will work I cant get any other year because of the solenoids or something any advice? Where is a good place to look? All junk yards around me say they dont have one so I'm lost
#2 Injuneer
  • 13689 posts
Posted 2 weeks ago
Correct, you specifically need a 1995 4L60E from a 1995 F-Body.  Earlier versions use simple on/off lockup.  95 uses pulse width modulated (PWM) converter lockup.  Later years are PWM, but have different 3->2 downshift strategy, and a different downshift solenoid and different control valve.  Details here:
http://www.ltxtech.c...nd-interchanges
Try parts wanted forums on sites like:
CamaroZ28.com
ltxtech.com
ls1tech.com
Or consider a quality rebuild.
https://cahallperfor...4l60e,-65e,-70e
#3 sea dog
  • 3029 posts
Posted 2 weeks ago
Try this salvage yard search engine. You can search your state. http://www.car-part.com
Are you sure that you need a new trans? I'm asking because there are codes that disable certain gears from engaging. and they don't light the cel. You can download the 95 service manual at the following link. The driveability & emissions section lists all the codes, what causes them to set, what pcm does when code sets, & troubleshooting. http://www.mediafire.../?40mfgeoe4ctti
Even though your 95 has the 16 pin obd 2 type aldl, it's an obd 1 computer system that needs an obd 1 scanner to read codes.
#4 JoePeek
JoePeek
  • 1432 posts
  • First Name:Joe
  • City:Westfield
  • State or Province:IN
  • Year: 1971
  • Engine: 455 HO
  • Transmission: 4 speed
Posted 2 weeks ago
Sounds like the 3-4 clutch pack is toast. Both shift solenoids are OFF in 3rd, so that rules out a shift solenoid. The seal around the 3-4 apply piston may have started to get blow by and then the 3-4 clutches start to slip and burn up. Being that a '95 is a unique year, and even if you find one in a junkyard, there is no reason to think it is in good condition as is. Many old cars are in the junkyard because the engine or transmission went bad, so it's a crap shoot you would even get a good one if you were to find a '95. What your options are are kinda based on what you can do yourself. Options range from replacing just the 3-4 apply piston and clutch pack, to getting a rebuild kit and replacing more stuff while the trans is out and opened up, to just replacing the whole thing with a rebuilt one, to just having a shop rebuild the one in the car. While one can't really sort out a car problem on the internet, it sounds like the 3-4 clutch pack is burned up, which is a common thing for the 4L60E.
#5 Tabbedout90
Tabbedout90
  • 5 posts
  • City:Cache
  • Engine: Lt1 5.7l
Posted 2 weeks ago
It shifts into third momentarily only to slip back out and feel like it's in neutral until u slow down a bit and 2nd kicks back in and then it does it again. I have a code reader and no trans codes are coming up only a code 26 for evap canister solenoid which I think is from a vacuum leak going into that solenoid
#6 sea dog
  • 3029 posts
Posted 2 weeks ago
Sounds like trans is toast.
If your willing to drive to Newman Lake Washington, there's a trans shop there owned by Jon. He's a member of the ls1lt1 forum. He's honest and does great work. It's hard to find trans shops that are honest & do good work.
Sorry that I don't have his last name. But you should be able to find him if you want him to rebuild your 4l60e.
Members from the ls1lt1 forum have had their transmissions rebuilt by Jon. He did excellent work on all of them.
#7 Tabbedout90
Tabbedout90
  • 5 posts
  • City:Cache
  • Engine: Lt1 5.7l
Posted 2 weeks ago
I appreciate that but Washington is a little too far for me I'm in oklahoma
