Remove Steering Wheel on 72 Formula - Second Generation Pontiac Firebird (1970 - 1981) - Firebird Nation
Steering Wheel
2 replies to this topic
#1 BARNFIND455HO
BARNFIND455HO
  • 1 posts
  • First Name:Steve
  • City:Salt Lake City
  • State or Province:UT
  • Year: 1972
  • Make: FIREBIRD
  • Model: FORMULA
  • Engine: 350
  • Transmission: AUTO
Posted 3 weeks ago
Mom and Dad have misplaced their keys on a 72 Formula.
I could use some help on how to remove the portion of the steering wheel to be able to access and remove the ignition lock to save the cost of an onsite visit from a locksmith.
I also don't want to damage the steering wheel wood applique.
Thanks
Edited by BARNFIND455HO, 3 weeks ago.
#2 JOE68
JOE68
  • 763 posts
  • First Name:Joe
  • City:waterford
  • State or Province:PA
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: ST300
Posted 3 weeks ago
any GM cylinders I have pulled requires the key to turn it to accy
#3 sea dog
  • 3032 posts
Posted 3 weeks ago
The process starts with removing the center section horn push. There are screws on the back side of wheel that when taken out will release the assembly so nut holding wheel to steering shaft can be removed.
However, the wheel will not just come off after removing the nut. You need a steering wheel puller to get wheel off shaft.
After that you need to remove switch assemblies, and lock ring. The lock ring requires a special tool to get circlip off so lock ring will come off.
Then after that, you will need the key to turn lock cylinder to accy position to remove lock cylinder. Also GM cars usually have a small screw that must be removed to get lock assembly out.
I've attached a pdf file of disassembling the GM steering column. It's for 4th gen cars but is pretty much like the 2nd gen column.
Also tagged with one or more of these keywords: Steering Wheel
