Tires Bias to Radial - Second Generation Pontiac Firebird (1970 - 1981) - Firebird Nation
4 replies to this topic
#1 Zeprocks#1
Zeprocks#1
  • 16 posts
  • First Name:Scott
  • City:Pawtucket
  • State or Province:RI
  • Year: 1970
  • Engine: 350
  • Transmission: Manual 4 speed Hurst
Posted 3 weeks ago
I'm changing from F70/14 F.S. Wide ovals to BF Good. Radial T/a's. Tire rack states the equivalent is 215 70R14 so can any one say for sure I can't go the next size up or will 225's fit? They don't recommend it. THX F.B.
#2 JoePeek
JoePeek
  • 1432 posts
  • First Name:Joe
  • City:Westfield
  • State or Province:IN
  • Year: 1971
  • Engine: 455 HO
  • Transmission: 4 speed
Posted 3 weeks ago
Not sure about this question, but when you go to radials, the front end alignment settings are a bit different. Years ago I remember looking at the castor, camber toe-in specs, for different years to set up my '71, even looked at second gen Camaro specs, While the same basic steering/suspension geometry was used from '70 to '81 F body, the front end settings were not the same through the years. Seems like when the factory went to radials, the front end settings changed as well.....which makes sense.
#3 NOT A TA
NOT A TA
  • 875 posts
  • First Name:John
  • City:Delray Beach
  • Year: 1970
  • Model: Esprit
Posted 3 weeks ago
They may not recommend the 225's based on the width of your wheels.
How wide are your wheels?
John Paige
Lab-14.com
#4 Zeprocks#1
Zeprocks#1
  • 16 posts
  • First Name:Scott
  • City:Pawtucket
  • Year: 1970
  • Engine: 350
Posted 3 weeks ago
Thanks guys... I have 14x7's
#5 Injuneer
  • 13689 posts
Posted 3 weeks ago
According to Tire Rack specs for the Cooper Cobra and the BFG Radial TA, a 225/70-14 is OK on a wheel between 6.0-7.5” wide.  The Cooper 225 is 1/2” larger in diameter and less than 1/4” wider section width.
According to Tire Rack specs for the Cooper Cobra and the BFG Radial TA, a 225/70-14 is OK on a wheel between 6.0-7.5” wide.  The Cooper 225 is 1/2” larger in diameter and less than 1/4” wider section width than the 215.
