Window Weather Strip... - Part Numbers - Firebird Nation
Rear Window Weather Strip
1 reply to this topic
#1 jrenaldy
jrenaldy
  • 1 posts
  • First Name:Jason
  • City:Kennesaw
  • State or Province:GA
  • Make: Firebird
  • Engine: 5.7 LT1
  • Transmission: Automatic
Posted 3 weeks ago
Hey guys,
Sorry if this topic has already been posted, but I need the part number (ID) for the rubber weather strip on the top of the rear window for a 1995 Formula.  I would greatly appreciate any info you can give me.
Thanks!
#2 Injuneer
  • 13693 posts
Posted 3 weeks ago
Assuming you mean the black plastic “lace” that surrounds the edge of the hatch glass.  That piece was a problem from day 1.  Oozed black yuck in the hot sun.
Early years only had a strip at the bottom of the glass.  My 94 (purchased new, saw it come off the truck) only has the piece on the bottom edge. At some point they added another piece at the front edge of the glass, going up and over the top. There were small 90-deg pieces connecting lower and upper strips on both sides.
Near the very end, they switched to a 1-piece full surround.  Shoebox shows the 1-piece part number as 10306248 “one piece lace for rear window”.  Don't know if it's still available, but at least it’s a starting point for a search.
