Y-pipes, cats and dropping weight CARD style - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
2 replies to this topic
#1 SoCalTA
SoCalTA
  • 169 posts
  • First Name:Jorge
  • City:Agua Dulce
  • State or Province:CA
  • Engine: LT-1
  • Transmission: M^
Posted 02 July 2020 - 03:53 PM
Hey Guys ...
I'm getting ready to reassemble my car, now that my headers are re-coated and I remember when I was taking the y-pipe off with the cat that it was pretty heavy.  I have a Borla set up from the cat back .... and so I was wondering if any of you have any recommendations on a CARB legal "Y" pipe that might give me more performance and not weight so damn much ....
Thanks
Jorge
#2 Injuneer
  • 13861 posts
Posted 02 July 2020 - 06:12 PM
What CARB-EO certified headers are you reinstalling?  Most of the dual-cat CARB-compliant headers were not impressive, because of the CARB (and Federal) requirement that the cats can not be relocated from their stock position.  As a result the driver side primaries looped up above the valve cover, overheated everything under the hood, and produced little in the way of gains.
There's a CARB website that lists all the CARB approved aftermarket parts like headers, cats, and probably the Y-pipe.  There's not much you can do to replace the weight of the cats.  So you're left with possibly a thinner gage metal for the Y-pipe tubing.  Not a lot there unless you can find someone the uses titanium.
#3 SoCalTA
SoCalTA
  • 169 posts
  • First Name:Jorge
  • City:Agua Dulce
  • Engine: LT-1
  • Transmission: M^
Posted 02 July 2020 - 06:43 PM
Hey Fred ...
What you described for the drivers side is exactly what I have  (JBA's to be exact) ... while not shorties I guess they are "mids" since the passenger side extends down to about where the dipstick enters the oil pan. I recently had them ceramic coated inside and out.  When I first purchased them they were coated by JBA and a few years into it, it toasted a few brake boosters...not fun .. along with a few other things ...  any whooo... I'll look and see whats out there on that site.... if I can make then lighter .. maybe better flowing cats ..... If they can be improved then why not ..
