Power seems to come to ignition but not out. - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
1 reply to this topic
#1 caner_saka
caner_saka
  • 16 posts
  • First Name:Caner
  • City:Mount Laurel
  • Interests:getting this bird running
  • Make: Firebird
  • Engine: 5.7 LT1
Posted 01 July 2020 - 10:29 AM
My 95 Firebird formula makes the dinging sound when you put the key in but does not send power back to on. If i send power directly through fuses the key can make the car crank but the key wont turn the instrument panel on itself just by turning to on. I think there's a problem with the ignition switch or the wires leading out of it and was wondering what I can do to fix this. Thank you!
#2 Injuneer
  • 13689 posts
Posted 01 July 2020 - 01:52 PM
Good writeup on the ignition switch.  First paragraph covers typical problems:
http://shbox.com/ign...witch_repl.html
Have you checked the fusible links that are used to distribute power from the battery:
http://shbox.com/1/fusible.jpg
Have you downloaded (free) the 1995 factoRyan service manual?  Great source of wiring diagrams and troubleshooting logic diagrams: (thanks to GaryDoug)
https://www.mediafir.../?40mfgeoe4ctti
Are you aware of the Shoebox website, best source on the internet for LT1 info:
http://shbox.com/1/4th_gen_tech1.html
