1998 V6 Oil Pump Failure - Pump Replaced now Issues - All Things V6 - Firebird Nation
6 replies to this topic
#1 Dave Hodge
Dave Hodge
  • 4 posts
  • First Name:Dave
  • City:Virginia Beach
  • State or Province:VA
  • Make: Firebird
  • Model: Base
  • Engine: 3.8 L V6
My Bird has 81k original miles with all servicing done by the book.  While driving up an entrance ramp the engine shut off and the car came to a rapid stop. Car would not restart, barely cranked. Towed to garage, Oil pump was seized up.  Replaced pump and Timing Cover. Now oil pressure when warm is below 30 when running and goes to 0 at a stop.  Mechanic noted a little rod knock. Sounds like more than a little to me.  What to do about the low oil pressure? What to do about the connecting rod?
#2 JOE68
JOE68
  • 750 posts
  • First Name:Joe
  • City:waterford
  • State or Province:PA
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: ST300
no easy fix for that one.....rebuild time
#3 sea dog
  • 2981 posts
By the time a connecting rod or main bearing starts to knock, the damage is done. The bearing surface on the crankshaft has been worn to the point that a new crank is needed. The damage is bad enough that crank can't be turned down to fix it.
#4 Dave Hodge
Dave Hodge
  • 4 posts
  • First Name:Dave
  • Make: Firebird
  • Model: Base
  • Engine: 3.8 L V6
Price wise what am I looking at to have the engine rebuilt?
#5 sea dog
  • 2981 posts
It depends on if your able to remove engine, then tear it down enough to take to a machine shop and have them do the machine work.
If your going to have a shop do the whole job start to finish, your talking thousands of dollars. I'm thinking 3k to 4K $$$
If you can do most of the work, I'm thinking you would still have about a thousand bucks in the job.
#6 Injuneer
  • 13599 posts
New GM long block - $2,811.
https://www.gmpartso...TMtOGwtdjYtZ2Fz
  • tom99 likes this
#7 tom99
tom99
  • 25 posts
  • First Name:Tom
  • City:st Louis
  • State or Province:MO
  • Year: 1999
  • Engine: 3800
Posted 3 days ago
Sent from my iPhone using Tapatalk can’t beat that, no stress about it being done right
Edited by tom99, 3 days ago.
