Transmission selection - First Generation Pontiac Firebird (1967 - 1969) - Firebird Nation
4 replies to this topic
#1 scorpeon
scorpeon
  • 4 posts
  • First Name:Martin
  • City:Calgary
  • State or Province:AB
  • Interests:Working on cars is my passion
  • Engine: 350
  • Transmission: 2sp powerglide
Posted 2 weeks ago
I have a 68 Firebird with the two speed powerglide transmission I need to know if I drop the transmission with a TH 350 bolt right up
#2 ponyakr
ponyakr
  • 4236 posts
  • First Name:don
  • City:jonesboro
  • State or Province:LA
  • Engine: 400,455
Posted 2 weeks ago
First you need to verify exactly what trans & engine you have. Is the 350 engine a Pontiac, Chevy, Olds, or Buick ?
Is the trans REALLY a Powerglide ? Or is it actually a 2-speed BOP trans, commonly called a Super Turbine 300 (ST-300) ?
A BOP engine requires a BOP TH350. A Chevy engine has a different bolt pattern, requiring a trans with a Chevy bolt pattern.
BUT, there are conversion plates which allows mating Chevy trans to BOP engine, & BOP trans to Chevy engine. I made one out of 1/8" plate. The bottom & dowel pin holes are in the same locations, for Chevy & BOP.
Don't know about driveshaft length. I've never switched from ST-300 to TH350. Some of these guys who have made the switched can tell you.  .
#3 scorpeon
scorpeon
  • 4 posts
  • First Name:Martin
  • City:Calgary
  • Engine: 350
I have a 350 Pontiac...Not sure about the (BOP)Transmission
Are there distinguishing marks on the transmission or just buy the serial number
#4 Martin Cooper
Martin Cooper
  • 38 posts
  • First Name:Martin
  • City:Estero
  • Interests:All things Pontiac
  • Year: 1967
  • Engine: 326
If your car is equipped with the original engine and transmission then you have the BOP 2 speed ST300 transmission. This transmission is frequently referred to as a Powerglide which was the Chevy 2 speed automatic. They are completely different transmissions. A BOP TH350 will bolt in where an ST300 had been, including the driveshaft and crossmember without modification, but the TH350 will require different means for controlling downshifts.
#5 scorpeon
scorpeon
  • 4 posts
  • First Name:Martin
  • City:Calgary
  • Engine: 350
Ok thanks
