Coolant Leak - General Engine (Non-Gen Specific) - Firebird Nation
Coolant Leak
6 replies to this topic
#1 cstiger29
cstiger29
  • 3 posts
  • First Name:Sidney
  • City:CLARKSDALE
  • State or Province:MS
  • Engine: 3.8L
  • Transmission: Automatic
Posted 05 May 2020 - 04:14 PM
I have coolant leaking from the holes behind the power steering pump of my Series II 3.8L. I just finished a refresh on the engine. I refreshed the engine because my intake gasket was leaking, but there was no external leak before. I also have a misfire code in cylinder #1 and 185 psi on that cylinder.
#2 sea dog
  • 3108 posts
Posted 05 May 2020 - 05:31 PM
Did you do a compression test on other cylinders? That way you could see if they have about the same compression. Do test other cylinders.
I'm not real familiar with the 3.8 v6. You need to remove pump and see if those hole communicate with water jacket. If they do either something was left off engine. Or you may need to put a bolt or stud coated with thread sealer into holes if threaded.
I'm not going to comment on the 185 psi compression on cyl #1. But don't be running engine much. This is because, if coolant is entering that cylinder, engine could be hydro locked by the water. But I'm being cautious as it's better to be safe than sorry. Plus, engines I've worked on that locked up do to water in cyl, had way higher compression.
So remove spark plug. Have assistant crank engine while you watch for coolant coming out of spark plug hole. And don't forget to get compression reading on a couple more cylinders.
#3 Injuneer
  • 13858 posts
Posted 05 May 2020 - 08:24 PM
Is it possible the plastic elbow(s) for the heater hoses, located behind the belt tensioner are leaking?  Very common problem on the 3800 engine.  Metal replacement elbows, with improved O-rings are available.
#4 cstiger29
cstiger29
  • 3 posts
  • First Name:Sidney
  • City:CLARKSDALE
  • Engine: 3.8L
Posted 06 May 2020 - 07:32 PM
That was the first place I checked. I already have the metal ones on there as I just refreshed the engine. They aren't leaking. The hole the coolant is pouring out of is threaded. I put a 8m fastener in it and it stopped. I going to the part store in the morning to find a fastener short enough to fit in the hole completely.
#5 sea dog
  • 3108 posts
Posted 07 May 2020 - 03:45 AM
Don't forget the thread sealant. I use the stuff made for plumbers.
#6 Injuneer
  • 13858 posts
Posted 07 May 2020 - 08:17 AM
What exactly did you do as part of "a refresh on the engine", beyond repairing the intake gasket?  Looking at the 3800 engine repair in the factory service manual, the engine has external thread block plugs for the coolant jacket, and one of them appears to be on the passenger side of the engine, at the front.  Is that possibly something that was removed as part of the "refresh"?
Personally, I'd be a bit concerned about a threaded hole in the front of the engine that is "gushing" coolant.  Something was not reinstalled.
Not trying to pester you.... Unfortunately, while this site has a number of 3800 owners, we don't get many responses from them.  In this case you received responses from two 4th Gen LT1 owners.  I will freely admit I know little about the 3800,  But when the 3800 owners don't jump in, I'm just trying to fill the void.
#7 cstiger29
cstiger29
  • 3 posts
  • First Name:Sidney
  • City:CLARKSDALE
  • Engine: 3.8L
Posted 07 May 2020 - 11:31 PM
Basically I removed everything but the camshaft and pistons, sent the heads off and went back with new gaskets everywhere. My assumption was that a plug was missing, but I don't remember removing one; nor do I understand why i would. Unless the previous owner removed it and replaced it with a fastener. This threaded hole is on the driver side. I removed most fasteners and plugged the holes before I painted the block. Being that it is behind the power steering pump, I can't imagine anything more than a plug was there. I put a 8m x 12mm fastener there and all is well as far as coolant leaks.
Now I'm troubleshooting rough idle and stalling that I assume is coming from a misfire. My scan tool is gave me P0155 (I think dont have it in front of me right now), P0301 and P0366. Did not have the last two codes before before I put the coolant in the engine. I'm assuming that maybe the coolant leaked on the camshaft sensor and made it go bad. Any suggestions? Going to try a new plugs and a wire set first.
