TORQUE SPECIFICATIONS - First Generation Pontiac Firebird (1967 - 1969) - Firebird Nation
1 reply to this topic
#1 DM3
DM3
  • 455 posts
  • First Name:Dirk
  • City:Cherry Hill
  • Year: 1967
  • Transmission: 4 Speed
Posted 12 March 2020 - 09:00 AM
I have complied a list of torque specs from several locations.  If you can add to the list, feel free.
Bolts or Parts                                                          Lube or Sealer                    Torque To:
Main Caps        Engine Oil                               95 ft-lbs
Rear Main Cap                                                           Engine Oil                               120 ft-lbs
Connecting Rod Bolts                                                 Assembly Lube                       45 ft-lbs
SD Connecting Rod Bolts                                           Assembly Lube                       65 ft-lbs
Cylinder Heads                                                           Engine Oil                               95 ft-lbs
Rocker Studs (screw in)                                             Engine Oil                               55 ft-lbs
Rocker Arm Nuts (nonadjustable)                              Assembly Lube                       20 ft-lbs
Rocker Arm Cover to Head                                        Dry                                          8 ft-lbs
Oil Pump Bolts                                                            Engine Oil                               30 ft-lbs
Oil Pump Cover Bolts                                                 Engine Oil                               15 ft-lbs
Windage Tray                                                             Engine Oil                               15 ft-lbs
Oil Pan        Engine Oil                               12 ft-lbs
Oil Filter Housing to Block        30 ft-lbs
Camshaft Thrust Plate                                                Engine Oil                               15 ft-lbs
Cam Sprocket/Timing Gear (upper)                           Thread Locker                        45 ft-lbs
Timing Cover to Block                                                Dry                                          35 ft-lbs
Timing Chain Cover to Pan                                        Dry                                          12 ft-lbs
Water Pump to Cover                                                 Dry                                          15 ft-lbs
Single Timing Cover to Intake bolt                             Install rubber O-ring with
          light RTV Silicone                   10 ft-lbs
Valley Pan Bolts                                                          Engine Oil                               15 ft-lbs
Intake Manifold (Cast Iron Heads)                             Non-hardening Sealer             40 ft-lbs
Valve Cover to Head                                                  Engine Oil                               8 ft-lbs
Exhaust Manifold to Head                                          Anti-seize Lubricant                40 ft-lbs
Intake Manifold to Head                                             Dry                                          40 ft-lbs
Spark Plugs (Gasket)                                                 Dry                                          25 ft-lbs
Spark Plugs (Taper Seat)                                           Dry                                          15 ft-lbs
Flexplate (Automatic)                                                 Tread Locker                          95 ft-lbs
Flywheel (Clutch)                                                        Dry                                          40 ft-lbs
Clutch Pressure Plate to Flywheel                             Tread Locker                          25 ft-lbs
Clutch Fork Ball Stud                                                  Dry                                          40 ft-lbs
Clutch Fork Rod Adjustment Lock Nut                       Dry                                          10 ft-lbs
Harmonic Balancer to Crankshaft                              Tread Locker                          160 ft-lbs
Transmission to Bellhousing                                       Dry                                          55 ft-lbs
Subframe Rear and Mid Position Bolts        75 to 95 ft lbs.
Subframe Front Bolts (radiator support)        30 to 40 ft lbs.
Oil baffle bolt to bearing cap                                      Locktite                                   15 ft-lbs
Starter to Block                                                           Dry                                          30 ft-lbs
Starter Rear Brace to Block                                       Dry                                          60 ft-lbs
Fuel Pump to Timing Cover                                       Engine Oil                               25 ft-lbs
Front Insulators (engine mounts)                               Dry                                          75 ft-lbs
Rear Insulator (tranny mount)                                    Dry                                          30 ft-lbs
Front Cover to Intake                                                  Dry                                          12 ft-lbs
Sprocket to Camshaft                                                 Dry                                          40 ft-lbs
Camshaft Retaining Plate                                           Dry                                          20 ft-lbs
Countershaft Stud Assembly to Cylinder Block         Dry                                          70 ft-lbs
Countershaft Stud to Side Rail                                   Dry                                          21 ft-lbs
Fan and Pulley to Water Pump                                  Dry                                          20 ft-lbs
Pulley to Balancer                                                       Dry                                          20 ft-lbs
Oil Drain Pan Plug                                                      Engine Oil                               22 ft-lbs
Steering Gear Mounting Bolts        70 ft-lbs
Pitman Shaft Nut        140 ft-lbs
Steering Wheel Nut        35 ft-lbs
Steer Coupling Nut        18 ft-lbs
Steering Coupler Clamp Bolts        30 ft-lbs
Tie Rod End Nut        35 ft-lbs
Tie Rod Clamp Nut        130 inch lbs
Ball Joint Nut (upper)        50 ft
-lbs
Ball Joint Nut (lower)        65 ft-lbs
Steering Arm Attach Nuts        85 ft-lbs
Lower Control Arm        85 ft-lbs
Upper Control Arm        50 ft-lbs
Brake Anchor Pin (drum)        130 ft-lbs
Brake bracket top anchor bolt (disc)        75 ft-lbs
Collar bolts        45 ft-lbs
(bolts that hold the large washer on the ends of the upper control arm shafts)
Wheel Stud (lug) Nuts        65 ft
-lbs
Twitter: @Dirk67bird
1967 Firebird 400
#2 sea dog
  • 2987 posts
Posted 13 March 2020 - 04:36 AM
Good info. I pinned tour thread at top of 1st gen section.
