Racetronix installation step - need verification - Fourth Generation Pontiac Firebird (1993 - 2002) - Firebird Nation
No replies to this topic
#1 SoCalTA
SoCalTA
  • 153 posts
  • First Name:Jorge
  • City:Agua Dulce
  • State or Province:CA
  • Engine: LT-1
  • Transmission: M^
Posted 07 March 2020 - 06:45 AM
Good Morning Guys ......
I finally got all the supporting parts I need to install the fuel pump housing and such into the tank and see if I can get her to run.
I have a question however, as I don.t have the assembly instruction.
Q: Inside the fuel bucket, at the bottom is a round opening where the umbrella valve sits.  At the bottom of the Racetronix fuel pump is the suction section that I want to assume should go into the round opening at the bottom of the bucket. So the outcome is that the fuel pump is sealed at the bottom... suction pulls up on the umbrella valve and allows gas to pass through ....
Is the above correct or am I way off.
oHHHH also.....have any of you used stainless wire or zip ties to keep the fuel bucket the and led fastened together in addition to the adhesive?
thank you,
Jorge
Edited by SoCalTA, 07 March 2020 - 07:33 AM.
