Transmission shifts out of O/D - All Things V6 - Firebird Nation
3 replies to this topic
#1 Mosseybige
Mosseybige
  • 2 posts
  • First Name:Ethan
  • City:Aspermont
  • Year: 1999
  • Engine: 3.8
  • Transmission: Automatic
Posted 25 February 2020 - 02:00 PM
I have a 99 v6 Firebird with 141k miles auto trans. I was driving down the road today and the transmission kept coming out of overdrive. Here is the kicker tho. If you are just trying to maintain speed 65/70/75 mph O/D comes out, BUT if you give it just enough throttle for the car to gain speed it will shift back into O/D, but as soon as you try to let off throttle enough to maintain current speed, it shifts back out of O/D. I have checked fluid level and it is just fine, with NO leaks... Is the Transmission out/going out?
#2 JoePeek
JoePeek
  • 1418 posts
  • First Name:Joe
  • City:Westfield
  • State or Province:IN
  • Year: 1971
  • Engine: 455 HO
  • Transmission: 4 speed
Posted 25 February 2020 - 04:09 PM
Are we talking the transmission shifts out of 4th down to 3rd, or is it the torque converter is falling in and out of lock up?
#3 Mosseybige
Mosseybige
  • 2 posts
  • First Name:Ethan
  • City:Aspermont
  • Year: 1999
  • Engine: 3.8
Posted 25 February 2020 - 08:08 PM
Well that's what I'm curious of. When it was doing that I DID switch it manually from D to 3rd, and you could here the RPMS come up just a little. Sooo I'm not 100% sure. I have little Knowledge on the powertrains on these cars. I did have a 24v Cummins that the PCM had grounding issues and I had to put a Manual switch to for the Torque Converter lockup. Otherwise it would basically do the same thing go in, and out, in, and out.
#4 Injuneer
  • 13599 posts
Posted 25 February 2020 - 08:31 PM
The F-Body 4L60E changed lockup strategy from “switched” to “pulse width modulated” starting in 1995, so its behavior is not going to be comparable to a switched system.
I would recommend you download (free, thanks to GaryDoug) the 1999 factory service manual.  The transmission section has a lot of troubleshooting and diagnostic charts.
https://www.mediafir.../?40mfgeoe4ctti
