Flashing The PCM - ECM/PCM - Firebird Nation
Flashing The PCM
13 replies to this topic
#1
  • 808 posts
Posted 11 October 2005 - 07:47 AM
Hey-
I read/heard... I dont really have any idea how I know this, but I heard from disconnecting the negative battery cable you reset your PCM or something like that....
If this is true, in theory, every time my battery dies my PCM gets reset, unless there is a separate battery in the PCM which uses the 12v ground from the battery... I dont know... So thats my question, every time my battery dies, is my PCM reset?
(Its dead now, I hate my fan toggle switch... I always forget about it lol)
:oops:
Thanks
jens
#2 mytmous
mytmous
  • 324 posts
  • First Name:Matt
  • City:Madison
  • State or Province:AL
  • Interests:Drag Racing, Working on Cars, My Wife and Kids
  • Year: 2001
  • Make: Caddy
  • Model: Catera
  • Engine: 3.0L
Posted 11 October 2005 - 08:51 AM
the true way is to pull the PCM fuse, then disconnect the battery for 15 mins.
that will reset it.
on the fan switch, you can hook up a relay that goes off a keyed 12V source that way it only gets power when you have the key on.
Matt aka Mighty Mouse
"Looking for a LS1"
#3
  • 808 posts
Posted 11 October 2005 - 08:53 AM
i was gonna do that matt, but i didnt know where i could get 25 amps from a keyed source...... i thought about using the lighter cuz that fuse blows at like 30, but i wasnt sure.... u talkin about the PCM fuse in the fusebox?
#4 mytmous
mytmous
  • 324 posts
  • First Name:Matt
  • City:Madison
  • Year: 2001
  • Make: Caddy
  • Model: Catera
  • Engine: 3.0L
Posted 11 October 2005 - 10:44 AM
pcm fuse yes
and as far as the keyed source, use a relay
main + to battery, main - to fan switch
mainkey + to keyed source(fuse size doesn't matter) mainkey - ground
use a 30amp relay.
the keyed power is like 1 amp not very much as it is just the trigger to
key the relay on and feed the power to the fan switch.
does this make sense?
"Looking for a LS1"
#5 mytmous
mytmous
  • 324 posts
  • First Name:Matt
  • City:Madison
  • Year: 2001
  • Make: Caddy
  • Model: Catera
  • Engine: 3.0L
Posted 11 October 2005 - 11:23 AM
see picture,
the keyed source only draws a little power to open the relay to let the
battery power go though to the fan switch.
"Looking for a LS1"
#6
  • 808 posts
Posted 12 October 2005 - 06:58 AM
i understand what youre sayin dude :rockon22: Id just need a place to put the relay, and a keyed wire. Its not all that bad when it dies, just a pain in the arse....
Hey do you think its necessary to reprog a PCM after putting in a new TQ convertor?
#7 mytmous
mytmous
  • 324 posts
  • First Name:Matt
  • City:Madison
  • Year: 2001
  • Make: Caddy
  • Model: Catera
  • Engine: 3.0L
Posted 12 October 2005 - 12:19 PM
Don't know I don't have a pcm controlled tranny.
the relays are small, you can stuff them under a console or behind the radio.
just tape them up good, and as far as a keyed wire, you can use the red radio power wire it's keyed, and would work well.
"Looking for a LS1"
#8
  • 808 posts
Posted 13 October 2005 - 08:56 AM
thanks matt, thats not a bad idea
#9 skeetwya
skeetwya
  • 461 posts
  • First Name:John
  • City:Moraga - east bay
  • State or Province:CA
  • Interests:F-body's, tennis, and girls... im a pretty simple guy
  • Year: 2000
  • Make: WS6 Hardtop
  • Model: 1/198
  • Engine: 350 ls1
  • Transmission: M6
Posted 14 November 2005 - 04:01 PM
back to the matter at hand. Yes, your PCM will reset if you pull the negative battery cable and it will most likley happen when your bat is drained too
had- 95 formula, 96 t/a, 2000 t/a WS6, 76 firebird esprit, 73 formula clone, 71 camaro, 77 corvette, 1999 T/A, 1999 v6 firebird, 1999 FRC (fixed roof coupe/hardtop) formula 1/1660ish
have- 2000 formula ws6 hardtop (I like saying FRC) even though i think fixed roof coupe is a corvette thing heh. 1/198 ls1 hardtop ws6's
#10
  • 142 posts
Posted 08 February 2007 - 12:44 PM
I got my pcm tuned(Thunderracing).....I had my fuse blowf or the pcm you think it reset my tuned back to factory?
#11 Injuneer
  • 13557 posts
Posted 15 February 2007 - 08:16 PM
I got my pcm tuned(Thunderracing).....I had my fuse blow  for the pcm  you think it reset my tuned back to factory?
<{POST_SNAPBACK}>
No. Pulling the power to the PCM simply clears the volatile memory. That's basically the long term fuel corrections and the learned IAC counts. The "program" for the tuning is in non-volatile memory, and will not be lost if power is removed.
Rather than pull the cable(s) off the battery, find the "PCM BAT" fuse, and pull that for 30 seconds. That is enough to reset the data stored in the volatile memory.
#12 yoheer
yoheer
  • 108 posts
  • First Name:Sergey
  • City:Minsk
  • State or Province:Other
  • Country:Belarus
  • Transmission: Automatic 4l60e
Posted 23 April 2020 - 06:50 AM
Hi everybody.
I have a bricked ECM from 94 car
It died while uploading .bin file via tuner pro rt.
Now the AN28F512 chips are desoldered. I need to flash them but i cant realize what files I need.
Is it a factory .bin file which was downloaded from ECM earlier? Should I flash both chips with it?
Or I need some specific files?
#13 sea dog
  • 2950 posts
Posted 23 April 2020 - 10:47 AM
If you would go to the gearheadefi forum they have  bin files for the 94 trans am with lt1. Just make sure you download the bin that matches your rear end gear ratio, automatic or manual transmission.  http://www.gearhead-efi.com
When you go there, search for 94 firebird bin files.
#14 yoheer
yoheer
  • 108 posts
  • First Name:Sergey
  • City:Minsk
  • Country:Belarus
Posted 26 April 2020 - 01:31 AM
Thanks for the reply
