Hooker Header Reviews? - Exhaust Product Reviews - Firebird Nation
6 replies to this topic
#1 xxinlinexx
xxinlinexx
    Firebird Tire Changer
  • 86 posts
  • First Name:Jeff
  • City:Miami
  • Year: 1977
  • Engine: 350
  • Transmission: Auto 4 speed
Posted 02 September 2011 - 05:29 AM
Anyone ever used these or know someone who has?
....Headers....
#2 Hartz
Hartz
  • 15 posts
  • First Name:Gary
  • City:Davison
  • State or Province:MI
  • Model: TransAm
  • Transmission: 4-speed
Posted 23 September 2011 - 05:35 AM
Looks pretty much like the set I just put on my 79 TA 400. The installation was pretty straight foreword - of course I had just reinstalled the engine so none of the linkages, etc were hooked up yet. If the headers have a slot for the numbers 5 and 6 cylinders, be sure to install the header bolt part way and then slip the flange over the bolt when you install the header. Good luck tightening up the bolt after that! You may also have to bend the oil dip stick tube down a little bit for clearance. The biggest problem I'm having is finding an oil filter that will fit through the tubes - the PF24 filter has too large a diameter. I'm going to try a Bosch 3423 or an AC PF61. If they don't fit, it's going to be a remote mount filter.
#3 xxinlinexx
xxinlinexx
  • 86 posts
  • First Name:Jeff
  • City:Miami
  • Year: 1977
  • Engine: 350
Posted 11 October 2011 - 04:52 AM
I just purchased them so we'll see how the install goes, i'll post up any issues.
Have you figured out that Oil filter issue?
#4 Hartz
Hartz
  • 15 posts
  • First Name:Gary
  • City:Davison
  • Model: TransAm
Posted 11 October 2011 - 04:21 PM
#5 Greenbird76
Greenbird76
    2nd gen. Firebird Owner
  • 455 posts
  • First Name:Ron
  • City:North Haven
  • State or Province:CT
  • Interests:I enjoy working on my cars and fixing whatever needs to be fixed. If I could stay in my garage 7 days a week, I would be very happy!
  • Year: 1976
  • Model: Firebird Esprit
  • Engine: 5.7 liter
  • Transmission: th700r4
Posted 11 October 2011 - 08:14 PM
I had them on my Pontiac 400 for a few years. Granted this was a while ago, but I bet they have not changed from the ones from 10- 15 years ago. I used a Fram filter, but I do not remember the size. Certain bolts were very hard to get to and I do remember removing motor mount bolts and lifting the motor and trans up a bit so I could sneak the headers in initially. I also did have some problems with them overheating my starter and I had to fabricate a heat shield. Otherwise pretty much the same with most cheaper headers- The paint will burn right off and they like to rust. Otherwise a good cheap alternative to the more expensive brands. I also have a pair on the chevy 350 that is in my car for the time being. I stripped and coated them with VHT's ceramic header coating in flat black and it holds up pretty well. Where as the bolts were hard to get to on the Pontiac, on the Chevy I have spark plug clearance issues and hate Accel shorty header plugs because they burn way to cold and love to foul. Hope this helps.
"Built the way Grandma wishes she could of ordered it- LEAN, MEAN AND GREEN!!!!"
Check out my full restoration post at AGTA. http://allgentransam...hp?topic=2327.0
Posted ImagePosted Image
#6 Blacksheep
Blacksheep
  • 119 posts
  • First Name:Dillon
  • City:Bloomington
  • Year: 1984
  • Model: trans am
  • Engine: 350
Posted 11 October 2011 - 08:37 PM
the new hooker header comps are JUNK lol they dont fit my 400 worth a crap it seems like they must of changed design because everyone with older hookers work fine my new ones sucked horribly. I didnt just get a bad batch i was sent another set saying they would fit perfect and still had the same issues. hope u have better luck
u must remove the oil filter bracket on the pass side and remove the starter on the driver side to install the headers.
on the 3rd bolt back on the pass side from the front let me know if u had clearnce too put in the bolt mine had to go in sideways because the tube is in the way
Edited by 78 TA, 11 October 2011 - 08:43 PM.
#7 Izzy
Izzy
    Oil Filter Technician
  • 976 posts
  • First Name:Ismael
  • City:South Gate
  • State or Province:CA
  • Interests:None
  • Year: 1967
  • Engine: 326
  • Transmission: TH-350
Posted 11 October 2011 - 09:02 PM
Yo,
I'm running the Hookers, no problems except the bolt tightning deal...LOL....it's late now, so I'll check the oli filter that I have tomorrow...it's fairly small so it might work for your application, or might be the same as the ones you mentioned and might not work, either way..I'll get back to you guys...Laters
