ignition switch in a 2000 Pontiac Firebird - Resolved Drivetrain Issues - Firebird Nation
11 replies to this topic
#1 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • State or Province:TN
  • Interests:Pontiac firebird, GTO's, fiero's
    Chevy trucks and camaros!
    football,fighting,cars.
  • Year: 2000
  • Engine: 3800 v6
Posted 18 November 2010 - 07:12 PM
i went out there today to the firebird to start it up and is tuck my key in and the key would not turn any way i tried everything it wouldent turn so after about an half an hour with messin with i figure out that to start it i have to put my key in and turn it backwards the turn it fron wards to start so i got it started but my key wouldent come out like it was stuck so i fianlly figure out that to turn the car off i must turn the key backward and give it a little jerk and pull out.
anyone have any ideas wat could be happening it just now happen to me tonight.
  • k&n cold air inatake
  • k&n oil filter
  • pacester headers, shortys
  • flowmaster dual exhaust
  • high flow magnaflow cat
#2 1993TransAm
1993TransAm
    DELCO NERD
  • 1799 posts
  • First Name:Simon
  • City:Central Ohio Region
  • State or Province:OH
  • Interests:Firebirds, Pontiacs, Oldsmobiles, Cadillacs, apparently Chevrolets too, W-bodies, professional automotive repair, automotive electronics and audio, body work, upholstery, detailing, weightlifting, NASCAR, baseball, football, heavy metal, big 80s hair/sweet mullets, and first and foremost my wife, family, friends, and the Almighty God.
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
  • Transmission: 4L60
Posted 19 November 2010 - 01:33 PM
Was your shifter firmly set in the "park" position when you initially tried to start the car and when you later tried to remove the key? Has this condition persisted over multiple attempts to start the car and/or remove the key from the ignition cylinder, or was it an isolated incident? :waitasec:
1993 Chevrolet Lumina Z34
1990 Chevrolet Beretta Indy
1992 Chevrolet Corvette
2017 Honda Civic EX-T Coupe
#3 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • Year: 2000
  • Engine: 3800 v6
Posted 19 November 2010 - 02:19 PM
it still happening and yes the gear shift was in park but i have a after market gear shift knob and i was tighting it up but thats it. i have to stick the key in and turn it backwards then turn it forward to start it and then its really hard to get the key out i have to turn it backwaards all the way and pulled real hard to get out.
  • k&n oil filter
#4 1993TransAm
1993TransAm
    DELCO NERD
  • 1799 posts
  • First Name:Simon
Posted 19 November 2010 - 04:01 PM
Did you just put this aftermarket knob on? Did this problem start shortly after you tightened the knob?
#5 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • Year: 2000
  • Engine: 3800 v6
Posted 19 November 2010 - 04:05 PM
i have this knob for ever it just started comin loose so i went out there and tightin the screw up on it and didnt think nothing about it then later that day i was about to leave and thats when my key wouldent start it up and it got stuck in the ignition.
  • k&n oil filter
#6 1993TransAm
1993TransAm
    DELCO NERD
  • 1799 posts
  • First Name:Simon
Posted 19 November 2010 - 04:10 PM
Back the screw out a little bit. I bet that's your problem.
I had a similar problem when I removed and replaced the stock shift knob in my car. I had to pinch the retaining staple a little bit to get it back into the slot on the knob. I must have pinched it a bit too much...for a couple weeks when I put the car in park, the transaxle lock would not engage and the key wouldn't come out of the ignition without subsequent attempts to put the car in park. After those couple weeks, the staple widened just enough to no longer interfere with the nylon rod that runs down the center of the shifter rod assembly. Essentially, if anything is interfering with the nylon rod's ability to slide completely downward when the car is in park, the transaxle will not lock and you won't be able to take the key out of the ignition. Next time this happens to you, try to lock your steering wheel. I bet it won't.
#7 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • Year: 2000
  • Engine: 3800 v6
Posted 19 November 2010 - 04:12 PM
ok let me go check ill be right back thanks for replying
  • k&n oil filter
#8 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • Year: 2000
  • Engine: 3800 v6
Posted 19 November 2010 - 04:21 PM
hey man i took the gear shift off and try the key and it works perfect didnt get stucked or anything i put the gear shift back on and tighting it up enough and it works perfect.
thanks man because i thought my igntion switch was bad or something/
  • k&n oil filter
#9 1993TransAm
1993TransAm
    DELCO NERD
  • 1799 posts
  • First Name:Simon
Posted 19 November 2010 - 04:22 PM
Glad you fixed it! :12EMOTICHEERS:
#10 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • Year: 2000
  • Engine: 3800 v6
Posted 19 November 2010 - 04:28 PM
yeah i know, Thanks again
  • k&n oil filter
#11 1993TransAm
1993TransAm
    DELCO NERD
  • 1799 posts
  • First Name:Simon
Posted 19 November 2010 - 04:34 PM
I consider this topic solved, I will move it to the appropriate forum.
#12 bird21
bird21
  • 491 posts
  • First Name:john
  • City:portland
  • Year: 2000
  • Engine: 3800 v6
Posted 19 November 2010 - 04:41 PM
ok.
  • k&n oil filter
