So I bought a V6 Auto Firebird from my best friend about 7 months ago, which had trouble starting up, it would take a few attempts to get it to start up, but when it finally did, it'd stay on. My friend (being the mechanic, and not me) Determined it was that the fuel pump in it was weak. After replacing it and the fuel filter, the car would start up instantly and ran like a dream. Now, 3 months after we put that new fuel pump in, I parked it 2 days ago, and it was still running more than fine. Then yesterday, getting ready for work, I turned the key and ran into this problem again. The car will crank but won't start up. I turned the key to the on position, and can hear the fuel pump make a bump noise, but that's about it, then it just stops.
I have no idea what the problem is, as I said before, I am no mechanic, but slowly learning, if it helps any, I just filled the tank back up to full and put some STP Fuel Injection cleaner in it, that's about all. My friend told me his 2 Firebirds (90 and 91 Formula) ran into the same problem, and so did his dad's friend's Trans Am, saying it was a common problem for Firebirds and TAs and that Fuel Pumps need to be replaced many times with these. I hope this is not the truth as I can't afford to continue buying a new pump every 3 months, and would be sad to see my Firebird go. So any help or insight on this problem is greatly apprectiated. Thank you everyone for taking the time on reading this post and in advance for any help offered.
Edited by Heart of Darkness, 28 June 2010 - 01:31 PM.
