Leaking Injectors - Resolved V6 Issues - Firebird Nation
Leaking Injectors
7 replies to this topic
#1
  • 11 posts
Posted 14 October 2009 - 12:13 PM
Alright, well i screwed up the original set of injectors, and after 3 weeks or so of the car sitting there, new injectors have finally come in the mail. I purchased Venom Hi-Flow injectors FYI. Now the issue is the 2 injectors on the right side closest to the rear are leaking fuel when i go to start it. I dont know why this is. Has anyone else had this issue and do they know the solution?
#2 FBN Firebird Nation
Posted 14 October 2009 - 12:22 PM
I believe Russ had a problem with his Venom injectors. Have you tried to swap those two injectors with injectors from the other cylinders to see if they still leak?
#3
  • 11 posts
Posted 14 October 2009 - 12:28 PM
no, but ill try that.
#4 FBN Firebird Nation
Posted 14 October 2009 - 12:55 PM
That is a quick way to asses if the injectors are faulty, or if it's something else.
#5 rusnrno
rusnrno
    Old and Slow
  • 4131 posts
  • First Name:Russ
  • City:Reno, Nevada
  • Interests:*Edit- Free, single and loving it! My two grown children and my Grandson and Granddaughter. My Firebird, Snow skiing, MMA fighting, woodworking, home and auto electronics, camping, rafting, work, and sleep.
  • Transmission: M6
Posted 14 October 2009 - 03:12 PM
I bought a set of Venom injectors for my Formula. They sucked. I returned them and bought some Ford injectors.
RIP Jay
I miss you already Bro'.
RIP-Brother Rat
1996 Formula
LT1, M6,Eaton Posi, Moser Axles, 4.10 Gears
CC305 Cam, Crane 10308-1 Valve Springs, Crane 11746 NSA 1.6 Full Roller Rockers, Trik Flow pushrods, LT4 timing set, Accel injectors, OBD1 conversion, CATS tuning software,
ARP head bolts and rocker studs,
no AC, no AIR, PCM tuned by ME, Pacesetter LT headers, no cats, SLP fan switch, UMI Lower Control Arms, UMI Panhard Bar, UMI LCA Relocation Brackets, UMI Tunnel mount Torque Arm, Edelbrock Strut tower bar, Billet valve covers, Drop Zone 1.8" lowering springs, LT4 Knock module, MSD6AL Ignition, Taylor Wires, B&M Shifter, Hypertech 160 T-stat, Power Slot brake rotors, Ram Air hood(functional), TA front bumper, Home-built "Stealth" sub enclosures, Torque Thrust II wheels with 275/40/17s, Toyo Proxes Drag Radials
#6
  • 11 posts
Posted 14 October 2009 - 10:03 PM
huh, im suprised u say they suck...ha, only because thats the opposite of what i heard just yesterday about the injectors, saying that they are a good brand.
#7
  • 11 posts
Posted 20 November 2009 - 08:57 PM
It turned out to not be the injectors, the injectors work great. The problem was that the steel line that comes off of the fuel rail, that attaches at a 45 degree angle held down by a large nut, need needed a gasket, and it was spraying out when it didnt have one. and i couldnt tell at first because i was looking at the pools of fuel at the injectors. so, problem solved.
#8 FBN Firebird Nation
Posted 20 November 2009 - 09:07 PM
Excellent, thanks for the update.
