Engine and tranny acting funny? - Resolved V6 Issues - Firebird Nation
8 replies to this topic
#1 88gtman
88gtman
  • 770 posts
  • First Name:"Scott"
  • City:Pensacola
  • Transmission: Auto 4 speed 4L60E
Posted 18 August 2009 - 02:21 PM
Lately I have been having an issue with my bird. When I first crank it up and drive it the shifts are real firm and the car will not go into 4th gear. If I crank it up and it is shifting real firm, I can drive it about 50 feet down the road turn the car off and wait about 10 seconds. Then crank it back up and the car shifts and drives fine. I am also having a idle issue. Sometimes it is idleing high around 1500 rpm and other times it idles fine at about 8-900rpm. The transmission issue seems to happen pretty regularly on a cold start up and the idle problem comes and goes. Any ideas has to whats going on? :)
Speed Kills. Drive an import live forever.
98 Pontiac Trans Am A4
Granatelli air lid, Pro Products 85mm Throttle Body, BBK SSI Intake Manifold, TSP Long Tube Headers, TSP ORY, Hooker Areo Chamber Catback, Custom Tune, BMR LCA's, BMR strut tower brace, Founder's adjustable torque arm, Founder's Panhard Bar, RPM slotted rotors, and EBC Red Stuff brake pads.
1/8th mile - 8.7593 @ 82.72mph before Throttle Body, Tune, Headers, Y pipe. New times will be listed when I can get to a track.
321rwhp 327rwtq
#2
    Firebird Tire Changer
  • 55 posts
Posted 18 August 2009 - 03:07 PM
have u checed the trans fluid, i had similar problem and i was low on r=trans fluid. and check into the air flow sensor for the idling problem i have idling problem right now and everytime i tae the air floe sensor off for a few minutes and put it back on it runs perfect the 3 days later it starts doin it again probaly time for a new one.
#3 FBN Firebird Nation
Posted 18 August 2009 - 03:16 PM
Ken,
Have you scanned the PCM for codes? I would test the TPS.
#4 88gtman
88gtman
  • 770 posts
  • City:Pensacola
Posted 18 August 2009 - 05:48 PM
The TPS and IAC were replace less than a year ago, but I have to say they have crossed my mind. I don't have any codes when this is happening, but I plan on getting my mechanic to hook it up and check the code history. I checked the tranny fluid first time this happened and the level looked fine. I am thinking maybe it is time to change the trannny fluid and filter. The transmission issue is my biggest concern. I may have to try changing the air flow sensor.
321rwhp 327rwtq
#5 SySTeMaT1c
SySTeMaT1c
    Tall
  • 760 posts
  • First Name:Shea
  • City:Boscobel
  • State or Province:WI
  • Model: Firebird Y87
  • Engine: 3.8
Posted 18 August 2009 - 05:56 PM
maybe you have a bad ground somewhere. i would check.
1996 Pontiac Firebird Y87: 3.42 Posi W/ Auborn LSD, 14.4:1 steering, Rear Disc, 275/40r17 Tires, WS6 T/A Wheels, AVS Tailshades
#6 BeeJay
BeeJay
    I am HERE
  • 39 posts
  • First Name:B.J.
  • City:Pensacola
Posted 19 August 2009 - 03:55 AM
lets work on that stuff this weekend Scott. i dont think i have anything going on.
#7 88gtman
88gtman
  • 770 posts
  • City:Pensacola
Posted 19 August 2009 - 02:23 PM
Sounds good! I was planning on messing with it Saturday Afternoon sometime.
321rwhp 327rwtq
#8 88gtman
88gtman
  • 770 posts
  • City:Pensacola
Posted 05 September 2009 - 06:31 PM
Talked to my mechanic and he told me it sounded like a TPS problem so I changed the TPS and what do you know problem solved. Man the engine seems to really depend on that thing. LOL
321rwhp 327rwtq
#9 FBN Firebird Nation
Posted 05 September 2009 - 08:08 PM
Great to hear Kenneth, and thanks for the update. :12EMOTICHEERS:
