dyno slip
6 replies to this topic
#1 badbird5.7
badbird5.7
  • 504 posts
  • First Name:Sean
  • City:Worcester,Ma
  • Year: 2000
  • Model: trans am
  • Engine: 5.7 ltr LS1
Posted 17 May 2009 - 05:39 AM
here's my numbers,car has bolt ons and has an A4 tranny
along with vid
Edited by badbird5.7, 17 May 2009 - 05:57 PM.
2000 Pontiac Trans Am WS.6
5.7 ltr LS1
Slp lid w/ holley powershot filter
Jaam Ram Air System
LT headers, ory, Slp loudmouth 1 exhaust
Slp manual fan switch
Tripple gauge pod
Aeroforce interceptor gauge
corvette fuel rail covers
Spohn shock tower brace
Spohn LCA's
Corvette ZO6 rims 17x8.5 front, 18x9.5 rear
#2 FSTLS1TA
FSTLS1TA
    FBN Master Technician
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • State or Province:LA
  • Year: 2000
  • Engine: LS1 Owns You
Posted 17 May 2009 - 07:04 AM
Great numbers
#3 FBN Firebird Nation
  • 36,186 posts
Posted 17 May 2009 - 07:12 AM
Excellent numbers Sean!
#4 mr71transam
mr71transam
  • 1,143 posts
  • First Name:Richard
  • State or Province:MA
  • Year: 1971
  • Engine: 455HO
  • Transmission: TH400
Posted 27 May 2009 - 09:46 AM
Sean Excellent numbers! What did you do to get the extra 44.94 HP?
#5 badbird5.7
badbird5.7
  • 504 posts
  • First Name:Sean
  • City:Worcester,Ma
  • Year: 2000
  • Model: trans am
Posted 03 June 2009 - 10:37 AM
the low number one is a break in run
5.7 ltr LS1
Jaam Ram Air System
Tripple gauge pod
Spohn LCA's
#6 84ta406
84ta406
    Tune up Technician
  • 590 posts
  • First Name:Joshua
  • City:Worcester
  • Year: 1984
  • Engine: 406ci sbc
  • Transmission: TH400, 4500 stall
Posted 03 June 2009 - 11:12 AM
Good #'s man!
#7 austin1982
austin1982
  • 484 posts
  • First Name:austin
  • City:vinton, iowa
  • State or Province:AL
  • Interests:i love cars and going fast as possible
  • Year: 1989
  • Model: formula
  • Engine: 350
  • Transmission: 700r4 auto
Posted 03 June 2009 - 11:15 AM
good numbers man!!!!!!! :peelout:
