changing rear brakes
7 replies to this topic
#1 97bluebird
97bluebird
  • 1,077 posts
  • First Name:nick
  • City:Russellville
  • State or Province:MO
  • Interests:Cars, guitars, and motorcycles
  • Model: trans am
  • Engine: 5.7 LT1
  • Transmission: 4spd auto
Posted 18 June 2006 - 01:02 PM
I am trying to change the rear brake pads on my T/A. How do I get the piston back into the caliper?
#2 FBN Firebird Nation
  • 36,186 posts
Posted 18 June 2006 - 01:44 PM
<{POST_SNAPBACK}>
First, open the master cylinder cap and remove some of the fluid. Then, use a very large c-clamp to SLOWLY depress it back in. Keep checking to make sure you don't overflow the master cylinder.
#3 hgffrank
hgffrank
  • 4,079 posts
  • First Name:Frank
  • City:Jackson
  • State or Province:MI
  • Interests:Not getting pulled over by coppers.
  • Year: 1983
  • Engine: LG4 305
  • Transmission: 5-speed manual
Posted 18 June 2006 - 01:57 PM
Ha Bob, Im not sure on the 4th gens, but dont they have the type that have to be turned to get them in?
If they are the push in type, I have used a pry bar for years. Just leave the old pads in and pry between the pad and the rotor, and work the cylinder back in. Then remove and replace the pads. I've always done it that way unless I had the screw in type. C-clamps can be a pain in the butt sometimes.
1983 Pontiac Trans Am w/305LG4 & 5speed manual & 4.93 gears
Automotive Certifications:
Brakes, Engine Repair, Engine Performance, Steering & Suspension
#4 FBN Firebird Nation
  • 36,186 posts
Posted 18 June 2006 - 02:08 PM
They are push in, that is how I did mine. :29snick:
#5 97bluebird
97bluebird
  • 1,077 posts
  • First Name:nick
  • City:Russellville
  • Model: trans am
  • Engine: 5.7 LT1
Posted 18 June 2006 - 03:45 PM
I figured it out. They are push in. I thought they were the turn in kind too.
#6 Legion
Legion
  • 571 posts
  • First Name:Steve
  • City:Evansville
  • State or Province:IN
  • Year: 1981
  • Engine: 454 bb
  • Transmission: TH 400 W/B&M shift kit
Posted 18 June 2006 - 03:47 PM
i just use the old pads and a large c clamp on disk brakes
454BBC,TH400 Trany,Lunati Voodoo cam /Duration 276/284, Lift .554/.572 True duals thrush glass pack mufflers,
Headman headers.Tunnel Ram Combo, Weiand Manifold/Dual Holley 450 cfm Carburetors.
Pete Jackson Timing gear. Koni SPA1 Drag Race Shocks
#7 pontech01
pontech01
  • 2 posts
  • First Name:David
  • Year: 1981
  • Model: trans am
  • Engine: 6.6
Posted 19 June 2006 - 04:33 PM
you can usually turn the piston back in with a pair of needle nose pliers, one end in each grove and twist, or you can get a rear disc brake caliper tool kit which will have all of the right adapters for many other jobs too..
#8 97bluebird
97bluebird
  • 1,077 posts
  • First Name:nick
  • City:Russellville
  • Model: trans am
  • Engine: 5.7 LT1
Posted 19 June 2006 - 06:29 PM
I have the tool for my Acura but the Bird doesn't have twist in pistons they are push in.
