Pontiac Engine and Torque Specs
4 replies to this topic
#1 Crispy
Crispy
    F.B.N. Audio Bling Team
  • 6,720 posts
  • First Name:Chris
  • City:Queens
  • State or Province:NY
  • Year: 1999
  • Transmission: 4L60E / 3:23 posi
Posted 15 February 2006 - 09:42 AM
Firing Order:
1 8 4 3 6 5 7 2
Distributor Rotation:
Rotor spins COUNTER CLOCKWISE
Torque Specs for Pontiac 265, 301, 326, 350, 389, 400, 421
Main Caps, lube with Engine Oil, torque to 100 ft-lbs.
Rear Main Cap, lube with Engine Oil, torque to 120 ft-lbs.
Connecting Rods, lube with Assembly Lube, torque to 45 ft-lbs.
SD Connecting Rods, lube with Assembly Lube, torque to 65 ft-lbs.
Cylinder Heads, lube with Engine Oil, torque to 95 ft-lbs.
Rocker Studs (screw-in), lube with Engine Oil, torque to 55 ft-lbs.
Rocker Arm Nuts (Non-Adjustable Rockers), lube with Assembly Lube, torque to 20 ft-lbs.
Oil Pump Bolts, lube with Engine Oil, torque to 30 ft-lbs.
Windage Tray, lube with Engine Oil, torque to 15 ft-lbs.
Oil Pan, lube with Engine Oil, torque to 12 ft-lbs.
Camshaft Thrust Plate, lube with Engine Oil, torque to 15 ft-lbs.
Cam Sprocket (upper gear), lube with Thread Locker, torque to 45 ft-lbs.
Timing Cover, lube with Engine Oil, torque to 15 ft-lbs.
Valley Pan Bolts, lube with Engine Oil, torque to 15 ft-lbs.
Intake Manifold (Cast Iron Heads), lube with Non- Hardening Sealer, torque to 40 ft-lbs.
Valve Cover, lube with Engine Oil, torque to 5 ft-lbs.
Exhaust Manifold, lube with Anti-Seize Lubricant, torque to 30 ft-lbs.
Spark Plugs, lube with Anti-Seize compound, torque to 20 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch), lube with Thread Locker, torque to 95 ft-lbs.
Clutch Pressure Plate, lube with Thread Locker, torque to 25 ft-lbs.
Centerbolt (Harmonic Damper), lube with Thread Locker, torque to 160 ft-lbs.
Bellhousing (Transmission to Block), lube with Engine Oil, torque to 25 ft-lbs.
If you see anything wrong or would like to add to this list please PM me and I will add the information you provide along with your name to give you credit.
1999 Trans Am - SLP Lid, SLP CAI, Magnaflow cat back, Tinted side markers, 5000k hids, kicker sub
1985 Monte Carlo SS - Restoration in Progress
Hang together, or we'll surely hang apart.
PAST F-BODS:
1980 Trans Am 400, 1995 Trans Am 355, 2001 Firebird V6, 1991 Trans Am 350, 1979 Trans Am 301
#2 Malik
Malik
  • 275 posts
  • First Name:malik
  • City:minneapolis
  • State or Province:MN
  • Year: 1981
Posted 18 June 2013 - 09:44 AM
good info
minneapolis, mn.......... only live once.
#3 Chuck_Neste
Chuck_Neste
  • 427 posts
  • First Name:Chuck
  • City:Kennesaw
  • State or Province:GA
  • Interests:Things
  • Year: 1970
  • Make: Firebird
  • Model: Esprit
Posted 16 March 2014 - 06:42 PM
This may be useful as well.
http://boxwrench.net...ont_265-455.htm
Chuck
Edited by Chuck_Neste, 16 March 2014 - 06:44 PM.
I may be ignorant but I am not stupid
#4 Daddy_ja
Daddy_ja
    Firebird Tire Changer
  • 93 posts
  • First Name:Jason
  • City:Warner Robins
  • Transmission: TH350
Posted 16 March 2014 - 06:55 PM
Thermostat housing bolts - 30 ft lbs I believe. Correct me if I am wrong.
Edited by Daddy_ja, 16 March 2014 - 07:05 PM.
#5 Gran Torino
Gran Torino
  • 8 posts
  • First Name:Carguy
  • City:Central Alberta
  • State or Province:AB
  • Interests:Cars,cars,cars...did I mention I like cars
  • Engine: 403
Posted 18 June 2014 - 03:57 PM
Thanks for taking the time to post this, great info to have in back pocket.
