Transmission slips when cold
9 replies to this topic
#1 FAST RS
FAST RS
    Third Gen V6 Tech
  • 1,217 posts
  • First Name:David
  • City:Thousand Oaks
  • State or Province:CA
  • Transmission: TH-400
Posted 19 December 2005 - 06:25 PM
When my car is cold the transmission seems to slip when going from a dead stop after about 2 minutes of driving it is fine and there are no problems. Any ideas what it could be i have not had a chance to check the fluid yet but it should be full I did a filter and fluid change about a year ago. It was rebuilt about 70,000 miles ago. It is a 700-R4
1968 Pontiac Firebird
455 bored .30 over with TRW forged pistons, Torker 2 intake, 750 cfm Demon Carb, ISKE Cam, Mallory HyFire ignition box with a Mallory unilight distributor Super Comp Headers, 3 inch cutouts, 3 inch exhaust into Flowmaster 40 series mufflers. Almunium Drive Shaft, All new suspension Eaton Springs out back Moog up front with KYB gas Adjusts all around.
1991 Camaro RS V-6
MODS: FAST CHIP STAGE 2
MSD 6 AL, MSD COIL
CAI, Underdrive pullys.
And some stuff i cant think of at the moment.
#2 Crispy
Crispy
    F.B.N. Audio Bling Team
  • 6,720 posts
  • First Name:Chris
  • City:Queens
  • State or Province:NY
  • Year: 1999
  • Transmission: 4L60E / 3:23 posi
Posted 19 December 2005 - 06:34 PM
Check you TV cable first. I have the same issues. My tranny jerks when its cold, but i have no problems if i let the car warm up for 5 minutes before I go. Just a suggestion, would be a cheap easy fix.
Good luck and keep us posted bro.
1999 Trans Am - SLP Lid, SLP CAI, Magnaflow cat back, Tinted side markers, 5000k hids, kicker sub
1985 Monte Carlo SS - Restoration in Progress
Hang together, or we'll surely hang apart.
PAST F-BODS:
1980 Trans Am 400, 1995 Trans Am 355, 2001 Firebird V6, 1991 Trans Am 350, 1979 Trans Am 301
#3 fireduck350
fireduck350
    Master Tech
  • 2,256 posts
  • City:Rock Hill
  • State or Province:SC
  • Interests:Cars
    Dogs
    Army
  • Year: 1990
  • Model: Firebird Formula 350
  • Engine: L98 350
  • Transmission: auto 700R4
Posted 19 December 2005 - 07:33 PM
This isn't going to sound right at all, but when cold sometimes this is normal. Not sure why, but when cold, some 700R4s will feel like they want to hold first gear longer, and may feel like they are slipping because it takes more to get them moving. Once they warm up a little, they are fine, and shift just fine. Now, pay close attention to this, and see if it is actually slipping, or just holding the gears longer. This will usually result in a harder upshift, because it is allowing more fluid pressure to build with the higher rpms. I'm not sure if it is due to sticking valves, or what, but I have seen some do this. I've seen others that won't. I've seen 4L60Es do this as well. Not sure why. Actually, watch a S10 with a 4.3L and 700R4 leave, and see if it doesn't sound a little odd when it is first leaving the line while cold. Just about every S10 with a 4.3L and a 700R4 does this, and so does the S10 Blazer with the 4L60E that I have. I spoke to a guy that has a 2000 S10 truck with the 4.3L and 4L60E, and he said that his does the same thing, and has done it since it rolled off of the dealer lot. So I'm not sure what to think of it. Anyway, try changing the fluid and filter and see if that helps. If not, then make sure it isn't slipping and it is just holding the gears a little longer until it warms up. If it is slipping, then you are seeing signs of other problems.
1990 Formula 350 w/SLP T-Ram
1978 TA w/Olds 455
1987 IROC
1970 Monte Carlo
#4 FAST RS
FAST RS
    Third Gen V6 Tech
  • 1,217 posts
  • First Name:David
Posted 19 December 2005 - 09:14 PM
Its slipping not holding it basicly feels like i am moving fine then stops accelerating and goes again.
I also notice my steering wheel is hard to turn in the morning as well and it is fine on fluid but the temp is only 50 outside not that cold. If it was 30 or colder i could see this being a problem. But in the afternoon the steering is fine but the tranny still does its thing so i dont think it is tempature related.
1991 Camaro RS V-6
MSD 6 AL, MSD COIL
#5 RamAirThree
RamAirThree
    Autobody and Restoration
  • 13,490 posts
  • First Name:Lou
  • City:Queens
  • Interests:American Muscle Cars, Motorcycles (preferably Harleys), Good music, great friends, my woman and family and that includes the pets....... Is there really anything else in this world worth living for?
  • Year: 1970
  • Model: FORMULA 400 RAIII
  • Engine: 400 Ram Air III
  • Transmission: Muncie CR 4/3:90 12 bolt
Posted 19 December 2005 - 10:50 PM
I suspect its the pump..... :lmao22:
1 of 32 "Drag Packs" made, 1 of a handful left in the world!
1970 Formula 400 RAIII / Muncie close ratio 4-speed / 3:90 Limited Slip 12 bolt Rearend.
All original and matching number car.
Posted ImagePosted ImagePosted Image
#6 FAST RS
FAST RS
    Third Gen V6 Tech
  • 1,217 posts
  • First Name:David
Posted 19 December 2005 - 11:52 PM
Which pump lol. The P/S pump the steering is only tight on the first turn after that its fine. The miles are begining to show. If only i can hold out until the 08 camaro comes out i want my first new car to be a camaro
1991 Camaro RS V-6
MSD 6 AL, MSD COIL
#7 fireduck350
fireduck350
    Master Tech
  • 2,256 posts
  • City:Rock Hill
  • Interests:Cars
    Dogs
    Army
  • Year: 1990
  • Engine: L98 350
Posted 20 December 2005 - 06:54 PM
When you pull the pan, inspect it carefully for anything odd that is in there. Also check the filter when you pull it off and see how it looks. Transmission flluid will thin out a little as heat is built up in the transmission and that will cause it to flow more easily, but transmission fluid isn't as suseptible to temperature as oil, and 50 degrees shouldn't be cold enough to do much to it.
1978 TA w/Olds 455
1987 IROC
1970 Monte Carlo
#8 jacobmh
jacobmh
    Firebird Tire Changer
  • 77 posts
  • First Name:Jake
  • City:Naugatuck CT
  • State or Province:CT
  • Year: 1987
  • Model: Trans am
  • Engine: 327
Posted 08 February 2006 - 05:36 AM
My car holds the shift longer snd it gives s harder shift when cold. I have no idea when the filter was changed last. I am going to do that this weekend
http://www.cardomain.com/ride/2169300
327 .060 Over
Wold Products Heads 76cc
Weind Stealth Intake Manifold
Edelbrock 650 Carb
Flow Master Exhaust
with headman headers
#9 Crispy
Crispy
  • 6,720 posts
  • First Name:Chris
  • City:Queens
  • Year: 1999
Posted 08 February 2006 - 05:55 AM
Could be the TV Cable, I had the same problems with my 91. I had to let the car warm up a while if I wanted to shift properly.
My suggestion to you is if the car has high mileage I'd just change the cable, it wears over time and is a cheap easy fix that will help with yoru shifts.
PAST F-BODS:
#10 FAST RS
FAST RS
    Third Gen V6 Tech
  • 1,217 posts
  • First Name:David
Posted 08 February 2006 - 08:54 PM
I adjusted the TV cable when i did my oil change and also added a QT of tranny fluid and it seems fine now. Also the PS pump is fine when cold but the weather has been warmer.
1991 Camaro RS V-6
MSD 6 AL, MSD COIL
