96 WITH CODE P1441😳😳 PLZ HELP
8 replies to this topic
#1 Ac7000
Ac7000
  • 4 posts
  • First Name:Antwon
  • City:St. Louis
  • State or Province:MO
  • Engine: 3.8
Posted 16 May 2017 - 11:06 AM
Car runs perfect in park, I actually get the full effect of my cars acceleration. When driving I have to lightly press on acceleration to let the car get up to speed if I try to just punch it up to speed it starts sputtering any help will be gladly appreciated
#2 ZumpTA
ZumpTA
  • 1,060 posts
  • First Name:Tony
  • City:Holiday
  • Transmission: 6-Spd
Posted 16 May 2017 - 12:36 PM
http://www.firebirdn...code-on-my-car/
-- Jeremy S. Anderson
-- Wernher von Braun
#3 Injuneer
  • 12,391 posts
  • City:East Brunswick
Posted 16 May 2017 - 02:11 PM
Fix the code. In effect, it"S a continuous vacuum leak. Not sure it's enough to cause the problems you describe, but fix the problem. The possibilities are a stuck open EVAP purge solenoid, a short in the wiring causing it to activate (open), the two lines on the solenoid are switched to the wrong position, vacuum detection switch is defective, or harness wires are shorted.
All of this is available in the 1996 factory service manual. There is a logic diagram showing how to work your way thru the diagnosis. You can download the manual free from this thread:
http://www.firebirdn...02-wiring-diag/
#4 Ac7000
Ac7000
  • 4 posts
  • First Name:Antwon
  • City:St. Louis
  • Engine: 3.8
Posted 16 May 2017 - 07:44 PM
I'm also getting p0300 for misfires maybe a bad coil pack I also need new fuel injections maybe these are playing a part as well , I went and bought a new solenoid and replaced it still has same issue also tried switching the wires around no change
#5 Injuneer
  • 12,391 posts
Posted 16 May 2017 - 08:03 PM
Not switching the wires.... switching the vacuum lines at the solenoid.
Stop buying parts, without checking things per the guidelines in the factory manual, or even what the posts here are suggesting. Did you try blowing thru the solenoid? Did you look for carbon particle buildup? "Parts replacement roulette" is a very expensive was to chase a problem.
When you say you bought a new solenoid and "it was still the same issue", do you mean you cleared P1441 and it came back? Or do you mean it didn't solve the "light throttle" and "sputtering" problem? I tried to explain that I didn't think P1441 was causing your problems. You just needed to get rid of the vacuum leak.
How did you determine you need new fuel injectors?
#6 Ac7000
Ac7000
  • 4 posts
  • First Name:Antwon
  • City:St. Louis
  • Engine: 3.8
Posted 17 May 2017 - 01:20 PM
I apologize I meant vacuum lines when I said 'wires' I didn't try to blow through the solenoid exactly how would I do it and where to look for the carbon particle built up? And what I mean is I had the code cleared off and it came back only that p1441 and p0300
As for the fuel injectors a guy who used to do minor work on the car told me the code appeared before but me personally I've never seen it even up til this point
#7 Injuneer
  • 12,391 posts
Posted 17 May 2017 - 01:28 PM
Which code did he say appeared before? P0300 indicates random misfires. It does not indicate the cause of the misfires - could be plug(s), plug wire(s), distributor, ignition coil, ICM, injector(s), sticky valve, weak compression, etc.. Don't see how P1441 could be related to the injectors.
#8 Ac7000
Ac7000
  • 4 posts
  • First Name:Antwon
  • City:St. Louis
  • Engine: 3.8
Posted 19 May 2017 - 08:52 AM
I never personally seen the code as far as injectors I'm leaning more towards the bad coil , My wire which leads to cylinder 1 was eaten up so I put electrical tape on it the code cleared a few weeks later it came back instead of buying a new full set of wires I bought a piece of crap universal wire and it cleared again. It came back again so I just changed them all had the codes cleared and the p0300, p1441 came back
#9 Injuneer
  • 12,391 posts
Posted 19 May 2017 - 11:45 AM
Plug wire? Never tape a high voltage (20,000 volts) ignition wire. Tape is useless in that situation.
