Subframe Connectors on a 67 convertable
sbc subframe bmr
7 replies to this topic
#1 jbleeg
jbleeg
  • 8 posts
  • First Name:Jerry
  • City:San Jose
  • State or Province:CA
  • Interests:Cars & Teardrop Trailers
  • Year: 1967
  • Engine: 326
  • Transmission: AT - Turbo 350
Posted 15 May 2017 - 01:28 PM
Doe anyone have experience with BMR subframe connectors on a 67 convertible?  I am trying to eliminate some of the Cowl Shake associated with these (convertible)  cars and am wondering if these will help reduce Cowl Shake. I have done most of the usual things on the car like Shocks, Front and rear Heavy Duty sway Bars, Rubber front suspension bushings, and recently updated the rubber body mounts to Urethane body mounts by Energy Suspensions. My car is a cruiser with a 326 and a turbo 350 AT. It does not see drag racing, or Track days, but does see some spirited driving. I am just so annoyed by the shakes and probably spoiled after driving my modern era BMW.
https://www.summitra.../model/firebird
#2 NOT A TA
NOT A TA
  • 523 posts
  • First Name:John
  • City:Delray Beach
  • Year: 1970
  • Model: Esprit
Posted 15 May 2017 - 04:51 PM
If you're going to put sub frame connectors in you need to put solid body mounts in. Do you have the cocktail shakers in?
John Paige
Lab-14.com
#3 jbleeg
jbleeg
  • 8 posts
  • First Name:Jerry
  • City:San Jose
  • Year: 1967
  • Engine: 326
Posted 16 May 2017 - 04:11 PM
Yes to the original Cocktail shakers. Why solid mount?. Seems the uerathane body mounts I just installed should be plenty stiff. I am not trying to race the car. It is just a cruiser and I am trying to lessen cowl shake and shudder. Anyone have a opinion? Do this help convertible and cowl shake?
#4 Brownie1981
Brownie1981
  • 493 posts
  • First Name:Steve
  • City:Maple Ridge
  • State or Province:BC
  • Year: 1981
  • Make: Firebird
  • Model: Pro Touring Trans Am
  • Engine: LS 3 525Hp
  • Transmission: Tremec T-56
Posted 16 May 2017 - 07:34 PM
The solid bushings really work best with sub frame connectors since they eliminate body flex, something that rubber and poly do not do as well. Some will tell you if you go bolt on SFC you can go poly, if you go weld in SFC then go with the solids.
BlackOut
1981 T/A
LS3
Link to build: http://www.speedtech...prod/prd287.htm
#5 NOT A TA
NOT A TA
  • 523 posts
  • First Name:John
  • City:Delray Beach
  • Year: 1970
  • Model: Esprit
Posted 17 May 2017 - 12:25 PM
I've done poly with bolt in connectors the past and doesn't work over time. Initially they seem like they're OK but over time/miles they fail. The polys deform and rather than rebound like rubber they stay deformed (pic below). You'll keep tightening the sub frame bolts when checking over the car and finding them not up to 90 lb ft.   Eventually you'll probably get creaking from the bolt in connectors.
Cowl shake can be caused by a number of different things. Shifted tire belt, wheel balance, axle bearing, wheel bearing, bad shock, driveshaft balance, control arm bushings, control arm mounting points, rear spring bushings, U-joint, and things like worn engine and trans mounts can all cause shake. Sub Frame connectors are more likely to enhance any mechanical issue rather than cure it.
Some things occur that can cause a shake you wouldn't think might occur. As an example; I've had tires rotate on the rim from hard braking and drag type launches. That threw off the balance of the wheel/tire combination enough to cause a slight shake. I now mark the tires/wheels on the inside so I can see if a tire rotated.
John Paige
Lab-14.com
#6 Terriblehondo
Terriblehondo
  • 427 posts
  • First Name:mike
  • City:cooper city
  • Transmission: M20 4 speed
Posted 4 weeks ago
Comparing the Firebird to a BMW there really is no comparison between the two.  Not fair to the Firebird. I had an E39 and an E36 convertible with sport packages either of them would have crushed my Firebird in any handling test. I would have thought the bolt on SFC's would be good with the poly bushings.  But looking at the bushings above would give me pause  Not a TA were those bushings from a street driven car?
#7 NOT A TA
NOT A TA
  • 523 posts
  • First Name:John
  • City:Delray Beach
  • Year: 1970
  • Model: Esprit
Posted 4 weeks ago
Those particular ones were from my own car and unfortunately I didn't save the really bad ones because they were not reusable at all. The ones in the pic I had kept for a bud who needed some to use temporarily till he got some solids. My car was used on street and tracks with bolt in connectors at the time. I've seen just as much damage on ones only used for street. There are newer style ones with a solid sleeve in the center that might hold up better but I just tell most people to either go rubber for a stock resto or solids for any performance application.
John Paige
Lab-14.com
#8 Terriblehondo
Terriblehondo
  • 427 posts
  • First Name:mike
  • City:cooper city
Posted 4 weeks ago
I had SFC's on my first 69 with the stock rubber bushings 38 years ago.  I put polys in mine recently but no SFC's on this one.  I will have to make sure I keep an eye on them.
