1st time Firebird owner
10 replies to this topic
#1 Birdoprey
Birdoprey
  • 0 posts
  • First Name:Mark
  • City:Roscoe
  • Year: 1973
  • Engine: 455 Pontiac
  • Transmission: Manual 4
Posted 2 weeks ago
 Hi guys,
 I just picked up a 73 Firebird from a friend that has had it sitting in storage for years. He picked it up around 5 years ago or so with the intention to making a Trans Am clone as he really wanted a 73 TA. Well, a few years ago he picked up a 73 SD 455 TA and has since almost forgotten about the poor Firebird. I just got it home a few hours ago and i've been really trying to identify what exactly i have and what all it needs. Here is what i know so far:
 73 Firebird Esprit.
 Originally came with a 350/2 bbl, but now has a 455/4bbl. There is a 455 cast into the block on the drivers side front close to the freeze plug.
 Has a 495106 intake. Can't remember the year that number showed, but it showed was same intake on the 350/400/455
 Has a 490143 drivers side exhaust manifold. I'm showing its from a 71 or so 350/400?
 Motor has a HEI distributer with Accel coil on top
 Heads are 4X. Looking through the oil fill, it "looks" like i can see screw in rocker studs
 Car has a Muncie 4spd with Vertigate shifter. From looking at how the shift linkage bolts to the tranny side cover, it looks to be a 63-68 Muncie.       Evidently a M20 or M21(i'm not sure how to tell which)
 Looks to be a Q-jet carb. Fuel inlet points to the passenger fender.
 The motor runs, but feels like its missing on a cyl or two. It revs kinda slow and its smoking out the exhaust. The amount of smoke seems to change every time i crank it. Sometimes not much, sometimes quite a bit. Car has dual exhaust(looks like 2" if that). Right side normally smokes more than the left side. Motor sounds pretty quiet with a small tick near the right side valve cover. Its not exhaust. Its very mild though. Reving the motor produces smoke from the drivers side valve cover vent. I do not see a PCV valve.
 At the moment, the only gauge that seems to work is the water temp. The tach does not move, nor does the oil pressure. I don't think the fuel guage reads right(shows over full). Not really paid attention to the alt gauge. I did notice there are two wires on the back of the alt with fuses. One of the plastic fuse holders is broke and there is no fuse. Could this be why no gauges work?
 The car had A/C and everything looks to be there but the compressor and the brackets for the compressor
 I did notice the dash looks like the ones i've seen on T/A's(brushed alum look?).
 The car has a rear window defroster(never seen this on one of these). Dunno if it works at the moment
 Someone installed a moon roof in the top of the car. I do not know if it leaks at the moment.
 The car has a dual scoop ram-air hood, i think its a Formula hood? Drivers side rear corner has a chunk missing and there are a few of the little "gills" at the back of the hood that are missing. There are a few of them in the glove box so maybe i can get those fixed?
 I do know the rear is a 10-bolt. There is a tag under one bolt that says to only use limited slip differential lube, so i assume it has a limited slip diff. I don't see any other tags that might point to the rear gear ratio. Anyway to tell with out pulling the cover and counting teeth?
 The body on the car is straight. Its UGLY! The vinyl top is mostly gone.
 Front seats came from some other car. I like them, but the blue clashes with everything else in the car.
 My favorite part are the air shocks in the rear! lol
 The front seems to sit kinda high. Surprised since the car has a bigger motor.
 Thats about all i know at the moment. I would really like to get it running better. Not really sure where to start. The motor seems to be missing and it does not get better revving it up. I hate to spend a bunch of $$$ for a carb(or spend time/$$$ rebuilding a carb that is trash) only to find the motor has issues. I would not mind pulling the heads for valve job/seals, but would hate to find there is a lot of wear on the cyl walls. Any suggestions?
 -Mark
Edited by Birdoprey, 2 weeks ago.
#2 Birdoprey
Birdoprey
  • 0 posts
  • First Name:Mark
  • City:Roscoe
  • Year: 1973
Posted 2 weeks ago
 Here are a few pics
 Forgot to mention i don't think the car originally had a manual tranny. The tranny tunnel looks butchered to clear the shifter.
#3 KeyKeeper
KeyKeeper
    ']['exXxas']['itan
  • 716 posts
  • First Name:Derrick
  • City:Jarrell
  • Interests:Drag racing, beer, woodwork, beer, horseshoes, beer
  • Engine: 355SBC
  • Transmission: 700R4
Posted 2 weeks ago
Looks like a solid start to a project to me!  If its blowing a lot of stuff out of the valve cover vent, then it most likely is a very tired motor and needs a full overhaul.
I prefer to drive short distances....1,320 feet at a time
356ci SBC 11.8:1, Eagle rotating assembly, Wiseco .125" dome pistons, Lunati .600/.600 255/263 @ .050 solid roller, HP xp 950, super victor, Dart Pro 1 215cc head 2.08/1.62, all MSD ign, 700R4 3500stall....a work in progress. Est hp 588 thru chambered mufflers
#4 Birdoprey
Birdoprey
  • 0 posts
  • First Name:Mark
  • City:Roscoe
  • Year: 1973
Posted 2 weeks ago
 Yessir, that's what I'm afraid of. Was hoping to not have to. Will have to wait til I get done with my son's 80 Camaro. Doing an LS swap with a Eaton TVS 1900 supercharger. As much as I wanna stay old skool and hop-up the 455, its very tempting to do an LS swap. Would prolly make more power, better fuel mileage and be cheaper than messing with the 455. Of course, it wouldn't be a 455....
#5 JOE68
JOE68
  • 192 posts
  • First Name:Joe
  • City:waterford
  • State or Province:PA
  • Make: firebird
  • Model: hardtop
  • Engine: 350
  • Transmission: auto-2 jetaway
Posted 2 weeks ago
I would do a compression test on all cyl and record them.     that will tell you where you are below
#6 Birdoprey
Birdoprey
  • 0 posts
  • First Name:Mark
  • City:Roscoe
  • Year: 1973
Posted 2 weeks ago
 I'll give that a look as soon as i can. Looks like bad weather out here for a few days. Will look for a break in the weather.
 Forgot to mention that the entire motor has been painted and has very little oil seepage. Looks like the motor had been rebuilt and not had many miles since it was parked. Of course everything has an inch of West Texas dust. Under that the motor looks VERY good and clean.
#7 Formula71
Formula71
    Garage Gopher
  • 3,919 posts
  • First Name:Layna
  • City:Omaha
  • State or Province:NE
  • Interests:hummmmmm, cars? lol
  • Year: 1971
  • Model: Formula Firebird
Posted 2 weeks ago
Welcome to FBN, and the Firebird addiction, lol.
If you decide to get rid of the q-jet, let me know what the numbers are on it, I'm looking for one to replace mine, lol.
#8 celticpiping
celticpiping
  • 3 posts
  • First Name:Rich
  • City:Auburn
  • State or Province:ME
  • Interests:Celtic music, God, Guinness
  • Engine: 5.7 LT1
Posted 2 weeks ago
welcome, and that looks like a sweet rig!
R
#9 Birdoprey
Birdoprey
  • 0 posts
  • First Name:Mark
  • City:Roscoe
  • Year: 1973
Posted 2 weeks ago
 Thanks guys! I'm excited about it. Just have to wait to mess with it much. Time and $$$$.
 Formula71, i'll let you know.
#10 Birdoprey
Birdoprey
  • 0 posts
  • First Name:Mark
  • City:Roscoe
  • Year: 1973
 Well, messed with the car this past weekend. Pulled the passenger side valve cover and discovered a few things. 1) The 4X heads have screw in studs. 2) The #4 intake rocker was turned sideways(not on valve or pushrod)! No wonder it was running rough. Fortunately, the adjusting nut was still on the stud. Bad news is someone used a non-locking nut on this one rocker and it backed off. I got one off a SBC i had and adjusted it. Cranked it up and it didn't run any better...:(
 The plug in that cal looked a little oil fouled and it was not firing when i tested it. Got a new set of plugs and the motor runs smooth now! It must have a stk cam as smooth as the motor runs. Had to turn the idle down.
 The bad news is it still smokes out the exhaust and the breather in the valve cover. The motor ran good enough that i decided to take it for a spin down the road. Tires had been flat for years and it hops pretty good at lower speeds. I've only had it up to 60mph so far. Motor runs good but smoked like a train. So far i've logged about 50miles in short stints and the smoking is much less. At idle it does not smoke at all. Does not smoke out of the valve cover breather at idle either. It does a little if you goose the throttle and does some out the exhaust as well. Much better than it was. Can't see smoke at all while tooling down the road. If you open the throttle it smokes but not near what it was before. Got on it a time or two but didn't rev it very high since the tach is not working for some reason. The back 2 barrels don't seem to be opening.
 The Mr. Gasket Vertigate shifter is lots of fun, though i'm gonna have to do something different with it. In 1st or 3rd the shifter almost touches the dash. A quick shift to 3rd results in smashed fingers! I think i'm gonna have a plate made so i can move the shifter back a few inches. Will probably have to fab some shifter linkage as well.
 One thing i noticed it the steering has a tight spot a little to the left of center. Its not horrible but makes it twitchy if you happen to be on that spot(slight curve to the left). Not sure at the moment if its a gear box issue or linkage issue.
#11 cajun
cajun
  • *FBNCC Officer
  • 2,088 posts
  • First Name:robert
  • City:Raceland
  • State or Province:LA
  • Interests:2nd generation Trans Ams and Camaros
    70's and 80's classic rock music; Styx, Reo Speedwagon, Kiss, Foreigner, Kansas and so on...
  • Model: trans am
  • Engine: 403
  • Transmission: automatic
Posted 3 days ago
Welcome to FBN and congrats on the car.
